Thread: Trouble?
View Single Post
Old 9th December 2014, 11:58 AM
That's what I'm beginning to suspect on mine, how easy to fit and how much are they?
It will require removing the lower dash trim under the steering wheel and I suspect also the air vent tunnel, so you can get access to the top of the pedal box. It's held in by two bolts (number 6 in the image).
After fitting, you then need to adjust it, and will need VCDS to do it. I've attached an image of the culprit and also the adjustment instructions.
The one on mine has the part number 028 907 475 BD ('01 3.7), diesel ones are BC, but can't confirm if all the petrol ones use the same part. Used one on eBay range from £46 (from A8parts) upwards.
