Old 7th February 2009, 07:34 PM
Ska's Avatar
Ska Ska is offline
Question Fairy lights... sorry I mean DRL mods?
What do you guys think about these? Depending on how Figure11 does with tinting the corner rear lights red I may do these LED mods as well as I have to replace the front headlight seals anyway. I won't stick them on the bumper or anything like that just in the head lights - Am I tredding the realms of Chavness?
http://cgi.ebay.de/TAGFAHRLICHT-60-L...3A1|240%3A1308
Your thoughts gentlemen and ladies if there are any on here
Old 7th February 2009, 08:27 PM
Ska I think mkoneman has already fitted some of these to his S8 so I guess he can tell you the pros and cons. personally i think they are a bit thin, i'd want mine to look more like the thicker generic LEDs on newer audis
Old 7th February 2009, 08:33 PM
Ska's Avatar
Ska Ska is offline
He has did he post it any where?
Old 7th February 2009, 09:35 PM
Oli18's Avatar
Oli18 Oli18 is offline
Hey Ska, he did on TSN - here
Source: mkoneman
-Oli
Audi A8/S8 D2 Flickr Group
Old 7th February 2009, 10:17 PM
Oli18's Avatar
Sorry - got off topic and have moved my post here.
Cheers,
Oli
Old 8th February 2009, 01:52 PM
S8yot S8yot is offline
Been think about the LEDs as well. Need to dismatle headlight (xenon plus) anyway as it's started to get condensation in it. Is this a straight foward operation? Will they need to be re-aligned afterwards?
Ska - you mentioned new seals, are these something that I should be able to get from the local dealer?
Cheers,
Mike
Old 8th February 2009, 02:28 PM
Botang Botang is offline
I personally think they would work better mounted in the plastic trim just below the headlight
Old 8th February 2009, 05:21 PM
I like the look. Botangs suggestion about setting them in the lower grill has been done on an S6. I am trying to find the link.
Old 8th February 2009, 05:33 PM
Ska's Avatar
Ska Ska is offline
@ S8yot- it's relatively painless you may be able to remove the glass in situ just need tro remove the trim below the lights & the indicator PFL. But just take out the light is what I'd do and try to buff up the 150k miles glass at the same time.
the seal is around £7 from the dealers took them 2days to get them in.
Under the headlights you say Botang; hmm... some photochopping is in order me thinks. I've found the bigger 10mm leds as well 6 in a row.
Old 8th February 2009, 05:49 PM
Found it. It was a Jetta not an A6.
Here
