Hi all,
Having been inspired by others recently posting their fault codes and now my house renovation is coming to a close, I thought i'd start tackling some of the fault codes on my 8. I have cleared the codes and driven the car for about 30 mins. The list below is therefor a 'fresh' list of codes. Would really appreciate your inputs into the list. The following are ones i'm ok to live without addressing: - Driver's door touch sensor (let's face, so many just have a mind of their own - not working half the time only to come to life again ![]() - TPMS - I have the control module but don't see it as a priority to buy 5 new sensors - EPB - it works 99% of the time...once a month i just have to use it a few times to clear the dash light which i know many others do also. Thanks, Oli VCDS Version: Release 12.12.2 Data version: 20140212 Monday,19,May,2014,17:11:14:17815 Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0E 11 31 13 15 16 17 18 19 1D 1E 25 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 72 76 77 VIN: WAUZZZ4E26N019357 Mileage: 185800km/115450miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: Not registered 0001 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 1D-Driver Ident. -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: Sporadic communication error 1000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Cannot be reached 1100 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI A000AGMª0070 Revision: --H01--- Serial number: AUX3Z0F0383869 Coding: 0011773 Shop #: WSC 00759 210 86480 VCID: 2241C55DFD8A660EAD3-8077 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 P HW: 09E 927 156 B Component: AG6 09E 4,2lTDI RdW 0030 Revision: --H01--- Serial number: 0076831 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 30653F15A366C49E2B7-8065 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0008557 Shop #: WSC 02313 000 00000 VCID: 2241C55DFD8A660EAD3-8077 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0F0383869 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: D8B527B56B567CDE037-808D Subsystem 1 - Part No: 4E0 905 852 E Component: ELV 1940 5 Faults Found: 00190 - Driver's Door Handle Touch Sensor (G415) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 14 Reset counter: 101 Mileage: 175808 km Time Indication: 0 Date: 2013.09.23 Time: 06:58:02 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 14 Reset counter: 88 Mileage: 175808 km Time Indication: 0 Date: 2013.09.24 Time: 11:16:08 01176 - Key 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 3 Reset counter: 255 Mileage: 182144 km Time Indication: 0 Date: 2014.01.31 Time: 11:51:10 00179 - Access/Start Authorization Antenna; Drivers Side (R134) 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 4 Fault Frequency: 6 Reset counter: 61 Mileage: 184064 km Time Indication: 0 Date: 2014.03.16 Time: 10:40:58 00956 - Key 2 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 12 Reset counter: 100 Mileage: 184432 km Time Indication: 0 Date: 2014.04.27 Time: 16:06:26 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 02313 785 00200 VCID: 244DC345E79E683EDFF-8071 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300AC067562505 Coding: 0000002 Shop #: WSC 00759 210 68801 VCID: 3A711D3D751A0ECE953-806F Subsystem 1 - Part No: 4E0 910 609 A Component: Bedienteil MMI H42 0020 Subsystem 2 - Serial number: 318HI037505510 Subsystem 3 - Serial number: 7429.08.030000000000010000ÿ Subsystem 4 - Serial number: 010000ÿ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 D Component: KLIMAAUTOMAT 016 0400 Revision: 00000030 Serial number: 00000000088042 Coding: 0022561 Shop #: WSC 02311 785 00200 VCID: 1C3DFBA5DFEE50FE67F-8049 1 Fault Found: 00819 - High Pressure Sensor (G65) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 10 Reset counter: 83 Mileage: 183479 km Time Indication: 0 Date: 2014.03.05 Time: 06:36:17 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q Component: ILM Fahrer H14 0230 Coding: 0133121 Shop #: WSC 02313 785 00200 VCID: 3669090D4102EAAE71B-8063 Subsystem 1 - Part No: 4E2 910 113 B Component: Wischer WWS D3 H50 0420 Coding: 00000036 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH11 0050 Coding: 00139548 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBF8049216 Shop #: WSC 00000 000 00000 VCID: 1C3DFBA5DFEE50FE67F-8049 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI A000AGSª0070 Revision: --H01--- Serial number: AUX3Z0F0383869 Coding: 0011773 Shop #: WSC 00759 210 86480 VCID: 2241C55DFD8A660EAD3-8077 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Labels: None Part No SW: 4E0 910 561 F HW: 4E0 907 561 F Component: ABSTANDSREGELUNGH03 0020 Coding: 0011154 Shop #: WSC 02313 785 00200 VCID: 254BDE41ECA49136C81-8070 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 013 - Check DTC Memory - Intermittent - MIL ON Freeze Frame: Fault Status: 10111101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 101 Mileage: 185800 km Time Indication: 0 Date: 2014.05.19 Time: 07:40:00 Freeze Frame: Temperature: 26.0°C Voltage: 9.09 V Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H12 3610 Revision: 91H12360 Serial number: 0037P000DLH0 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 2757D44996A88326FAD-8072 Subsystem 1 - Serial number: 63328RB400E24D6EV Subsystem 2 - Serial number: 63428RB400E2571CK Subsystem 3 - Serial number: 63528RB400E2571DM Subsystem 4 - Serial number: 63628RB400E256F4R Subsystem 5 - Serial number: 63729RB400D364F8W Subsystem 6 - Serial number: 63829RB400D364A8S 1 Fault Found: 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 225 Mileage: 177172 km Time Indication: 0 Date: 2013.10.13 Time: 00:00:08 ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112151 Shop #: WSC 02311 785 00200 VCID: E5CB1E412C24D136881-80B0 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 980 N HW: 4E0 920 980 N Component: KOMBIINSTR. VDO H70 0410 Revision: D02 Serial number: AUDID3F0000091 Coding: 0000403 Shop #: WSC 00759 067 57207 VCID: 3261351DAD6AF68E5D3-8067 1 Fault Found: 16346 - Control Module - ROM Error 014 - Defective Freeze Frame: Fault Status: 00000011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 60685 km Time Indication: 0 Date: 2008.10.08 Time: 08:32:47 ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 A HW: 4E0 815 069 F Component: Heizgeraet H07 0110 Revision: 0000000C Serial number: 00000009006406 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 1A31FDBDD5DA2ECE753-804F 2 Faults Found: 01412 - Glow-Plug with Flame Monitoring (Q8) 008 - Implausible Signal 02251 - Heater Unit Locked 000 - - ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 B HW: 4E0 907 468 F Component: Gateway H11 0090 Revision: 11 Serial number: 19004061088029 Coding: FEFFFBDF2B7504 Shop #: WSC 02313 785 00200 VCID: 2757D44996A88326FAD-8072 3 Faults Found: 01325 - Control Module for Tire Pressure Monitoring (J502) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 61 Mileage: 175805 km Time Indication: 0 Date: 2013.09.01 Time: 16:38:45 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 254 Reset counter: 61 Mileage: 175805 km Time Indication: 0 Date: 2013.09.01 Time: 16:38:45 00467 - TV Tuner (R78) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 92 Mileage: 184441 km Time Indication: 0 Date: 2014.04.27 Time: 16:07:10 ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl Part No SW: 4E0 910 218 HW: 4E2 905 218 Component: FPI_1 H06 0060 Revision: 06000106 Serial number: 11082004063652 Shop #: WSC 00048 210 176595 VCID: DEB931AD097282EE49B-808B 1 Fault Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 0 Reset counter: 170 Mileage: 175792 km Time Indication: 0 Date: 2013.09.01 Time: 16:41:28 ------------------------------------------------------------------------------- Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H20 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 00000 000 00000 VCID: 2B5F28794A40A7461E5-807E No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0F0383869 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: D8B527B56B567CDE037-808D Subsystem 1 - Part No: 4E0 905 852 E Component: ELV 1940 4E0905852E ELV 1940 5 Faults Found: 00190 - Driver's Door Handle Touch Sensor (G415) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 14 Reset counter: 101 Mileage: 175808 km Time Indication: 0 Date: 2013.09.23 Time: 06:58:02 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 14 Reset counter: 88 Mileage: 175808 km Time Indication: 0 Date: 2013.09.24 Time: 11:16:08 01176 - Key 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 3 Reset counter: 255 Mileage: 182144 km Time Indication: 0 Date: 2014.01.31 Time: 11:51:10 00179 - Access/Start Authorization Antenna; Drivers Side (R134) 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 4 Fault Frequency: 6 Reset counter: 61 Mileage: 184064 km Time Indication: 0 Date: 2014.03.16 Time: 10:40:58 00956 - Key 2 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 12 Reset counter: 100 Mileage: 184432 km Time Indication: 0 Date: 2014.04.27 Time: 16:06:26 ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 J HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 6310 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2A512D7D85BABE4EE53-807F 2 Faults Found: 01772 - Signal from Level Control Pressure Sensor (G291) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 16 Reset counter: 92 Mileage: 177332 km Time Indication: 0 Date: 2013.10.21 Time: 21:55:34 01398 - Signal Conductor for Central Locking; Doors Open 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 96 Mileage: 185780 km Time Indication: 0 Date: 2014.05.16 Time: 15:24:48 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063342 Shop #: WSC 02313 785 00200 VCID: 244DC345E79E683EDFF-8071 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 D Component: MNS ECE H47 1060 Revision: 00000000 Serial number: 364AS067525548 Shop #: WSC 02313 785 00200 VCID: 3B7F18397A2037C68E5-806E 1 Fault Found: 02261 - Data Medium 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 7 Fault Frequency: 1 Reset counter: 84 Mileage: 185475 km Time Indication: 0 Date: 2014.05.04 Time: 13:56:34 Freeze Frame: Hex Value: 0x5366 Hex Value: 0x4712 Hex Value: 0x1A00 Hex Value: 0x6AC4 ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H03 0090 Serial number: 00000534600055 Coding: 0036036 Shop #: WSC 02313 785 00200 VCID: 1D3BF6A1C4F459F6901-8048 5 Faults Found: 02139 - Control Circuit for Left Front Interior Lights 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 198 Mileage: 177656 km Time Indication: 0 Date: 2013.10.30 Time: 19:50:00 01370 - Alarm triggered by Interior Monitoring 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 76 Mileage: 0 km Time Indication: 0 Date: 2014.04.28 Time: 09:59:00 Freeze Frame: Bin. Bits: 00000001 02138 - Control Circuit for Front Right Interior Lights 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 15 Reset counter: 56 Mileage: 177656 km Time Indication: 0 Date: 2013.10.30 Time: 19:02:00 00211 - Control Circuit for Rear Illumination Lights 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 15 Reset counter: 52 Mileage: 177656 km Time Indication: 0 Date: 2013.10.30 Time: 19:20:00 00215 - Control Circuit for Reading Lights Rear Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 198 Mileage: 177656 km Time Indication: 0 Date: 2013.10.30 Time: 19:22:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 B Component: Türsteuer.FS BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 2045CF55F386741EBB7-8075 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 B HW: 4E0 907 289 Component: Komfortgeraet H05 0010 Revision: 00100005 Serial number: W040601170155 Coding: 0004349 Shop #: WSC 02313 785 00200 VCID: 2855D7759BB68C5EF37-807D Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P14H06 0070 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H04 0020 1 Fault Found: 02107 - Trunk or Luggage Compartment Opening Motor (V254) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 89 Mileage: 185654 km Time Indication: 0 Date: 2014.05.08 Time: 17:57:39 ------------------------------------------------------------------------------- Address 47: Sound System Labels: None Part No SW: 4E0 910 466 D HW: 4E0 035 466 Component: BO_D3 H06 0320 Revision: 11S00002 Serial number: 00504060002262 Coding: 0000023 Shop #: WSC 00759 210 86480 VCID: 2757D44996A88326FAD-8072 Subsystem 1 - Part No: 4E0 910 465 B Component: BO_D3_SLAVE H31 0310 Subsystem 2 - Serial number: 01901060000773 Subsystem 3 - Serial number: 0219.01.060000000100030013ÿ Subsystem 4 - Serial number: 030013ÿ No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000078312 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E39F1ADC9F242EE89B-804B No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 B Component: Türsteuer.BF BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 2045CF55F386741EBB7-8075 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0001031 Shop #: WSC 02313 785 00200 VCID: 1F47CCA9CEF84BE682D-804A 1 Fault Found: 02433 - Supply Voltage for Right Parking Brake Motor (V283) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00111011 Fault Priority: 1 Fault Frequency: 9 Reset counter: 99 Mileage: 178392 km Time Indication: 0 Date: 2013.11.30 Time: 16:10:59 Freeze Frame: Voltage: 12.32 V Count: 93 ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 F Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000006 Shop #: WSC 02313 785 00200 VCID: 3D7B1621643439F6B01-8068 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 L Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 304AS067613997 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 31633A11A86CCD96249-8064 No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 A HW: 4E0 919 148 Component: R0078 TVhybridTuner 0280 Revision: R0H05000 Serial number: 76300700425102 Coding: 0000003 Shop #: WSC 02313 785 00200 VCID: 2143CA51F88C7D16B49-8074 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000010029 Shop #: WSC 00759 210 61239 VCID: 2045CF55F386741EBB7-8075 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 2601300067 Coding: 344530393135313035412056413032363031333030303637 Shop #: WSC 00000 128 00289 5 Faults Found: 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 19 Reset counter: 255 Mileage: 175823 km Time Indication: 0 Date: 2013.09.24 Time: 11:36:10 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 6 Reset counter: 255 Mileage: 177211 km Time Indication: 0 Date: 2013.10.19 Time: 02:38:35 00992 - Consumption Cut-Off Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 177153 km Time Indication: 0 Date: 2013.10.10 Time: 15:29:14 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 10 Reset counter: 255 Time Indication: 0 Date: 2013.10.19 Time: 02:07:13 02277 - Quiescent Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 181013 km Time Indication: 0 Date: 2014.01.20 Time: 08:11:01 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Türsteuer.HL BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 1E39F1ADC9F242EE89B-804B No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000601130467 Shop #: WSC 12336 024 394758 VCID: 3669090D4102EAAE71B-8063 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Türsteuer.HR BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 1E39F1ADC9F242EE89B-804B No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0030 Revision: 00H12000 Serial number: 08720602003606 Coding: 0301008 Shop #: WSC 02313 785 00200 VCID: 234FC059E2906F06A65-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 M HW: 4E0 862 335 Component: Handyvorb2 H13 1130 Revision: 00000000 Serial number: 00000007608675 Coding: 0010900 Shop #: WSC 00000 000 00000 VCID: 2C5D2B658F4EA07E17F-8079 No fault code found. End ---------------------------------------------------------------------
Are you sure you cleared the faults, theres loads of stuff on there from years back???
Del ![]() |
Component protection on the airbags is an interesting one.. Also check the coding on the CAN gateway, that may be part of the errors for the dash/ACC.
Most of the others are the usual random D3 messages, though I'd look into the Aircon pressure unit, shouldn't be anything to worry about, but could cause issues.
Like the others have said. you got codes back from 2013.
Clear all DTCs, go for a drive and rescan. If you could strip out all the ones with out faults, that would make it easier to read as well.
