D2 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
Half a mile if that from home the car died on me
![]() ANY IDEAS ANYONE
![]() Last edited by A8 Owner; 9th August 2009 at 09:29 PM. |
the auto switch to petrol is more due to fuel level alerting rather than 'if its not running on LPG' so thats why it won't switch when you have teh LPG issue.
I assume its not running on any cylinders at all from your comment re injectors? Check the filters aren't blocked ( LPG has whats called 'heavy ends' which collect over time and can block teh filters). You don't say what make of LPG system it has installed but my first point of call would be an installer who specialises in that make of kit and get them to run a diag on teh LPG ECU. It could be something simple like a fuse on teh LPG system thats failing. IIRC LPG systems are set to fail-safe so any issues means it will shut down rather than run and potentially cause engine damage. LPG does need a good spark more so than petrol but if its running fine on petrol then that should be enough that it would run somewhat if not optimally. Water level is only really critical on cold days. teh vapourisors have a warm water feed to assist in teh conversion of teh liqued gas under pressure to gaseous state for the injectors. in reality above 10 C it will happen without any water feed anyway. You could check that gas is being generated by popping off the output hose for a second or two ( Make sure you do this outside with plenty of ventialtion and obvioulsy no SMOKING!!!! ![]() ![]() |
Hi its a BRC system, ive rang the main uk suppliyer and the garage it was fitted at. Both r saying take the pipe off to check. Poss probs r
1/ Solinoids. front or back 2/ LPG ecu Steve cant find the front one as yet to c if he can hear it click.
all sorted. steve found no power going to solinoid (spelling wrong) but couldnt see why. We rang a LPG fitter who said theres no fuses inline, and said bring it the 60mile round trip and he will do it.
So steve gave up looking for a fuse as he said there wasnt one. Well we got there, took the wiring off tank put meter on just as steve did. He said the same as steve no power to tank, he then went under bonnet pulled cover off ecu to uncover 3 fuses, (that he told us there isnt any on phone) changed fuse and it worked. Well as u can guess Steve had a fit on him. He could of done this himself, if he had said there were fuses and where to look. So cost for a fuse was £40 fuel 50p fuse 5min labour £10 Im just happy shes all working
Brilliant! Glad it's all working again
![]() CURRENT: 2006 Audi A8 D3 4.2 Tdi QS - CLICK HERE FOR PROJECT THREAD: Audi Exclusive Azure Blue, Amaretto brown interior, facelift rear lights, S8 mirrors, B&O, ACC, Digital TV, glass sunroof, Fridge, Extended Leather Pack 2, wooden steering wheel & gearknob, keyless entry, keyless start, electric boot, softclose doors SOLD : 2000 FL Silver D2 4.2 QS - Solar sunroof, Bose, Blinds, NavPlus, Playstation, DVD, wireless headphones, iPhone AV connection, RS6 steering wheel, chrome mirrors, phone prep, xenons, servotronic steering, Rear screen, TV-in-motion, NavPlus Alu rings, S8 exhaust, S8 bonnet grille, 385mm D3 S8 brakes, rubber winter mats, De-badged rear, US rear indicator clusters, 20" Final Edition diamond cut wheels, 15mm Eibach Pro spacers (front), 20mm H&R hubcentric spacers (rear). Audi A8/S8 D2 Flickr Group |
yep, happy for you but as you say, doesn't bode well as a dealer/servicing business when you will rip off a client for teh sake of a tenner to change a fuse you won't tell the owner about.....
If I was you I'd be finding out if anyone else near can service BRC kit and when you find one I'd ring bloke up and tell him why he has lost all your future business including potentially a fitting to your next motor. |
