This was not a good day
![]() I'd booked the car in for the second attempt at the B7 RS4 rear brake upgrade. This time everything was prepped and ready (or so I thought). The STEEL (note the capitals) hubs had been drilled out to accommodate the new calipers and powder coated for some durability. I have everything to do the conversion ![]() New wheel bearings (Audi wanted £104. 'For the pair?' I asked hopefully ) ![]() 5 litres of dot 5.1 brake fluid calipers and discs new bushes and brake hoses etc. The wheel bearing pressed in like a dream. My confidence was mistakenly growing. Next the bushes. Would they seat properly? Would they feck ![]() ![]() We then trial fitted the hub and found a 2-3mm gap and too much play in the joint for it to be safe to continue ![]() So attempt 2 failed miserably. STEEL hubs do not fit ALUMINIUM suspension. Not to be put off and still having the rest of the day we checked the car out and found: A leak, sorry leaks on the steering rack. Replacement needed. A coolant leak, which we found to be the radiator after pressure testing the system. An oil leak on the sump. The offside CV boot had eaten itself (replaced less than 6 months ago) and the nearside boot is on it's way out (also replaced recently). The front top rear suspension arm is worn and has play in it (yes it is the awkward one where the bolt is behind the spring). New I'm really p1ssed off and decide to try something a bit easier. Replacing the faulty parking sensors can't be that difficult can it? WRONG! The rear sensor was easy. 10 minutes max. The front sensor is a bumper off job, so we start to remove the front bumper. We work out how to remove it but the fecking bolts won't move. ARRRGH!!! The car has had a minor bump which has bent and cracked the bump stops and we think has also bent the bolts holding the bumper on. I'm not going to start on trying to replace the aerial. That's another post! Sooooooooooo... in 7 hours we've replaced a CV boot and a rear parking sensor. What a feckin' day ![]() |
ah mate - all i can say is good effort!
To be fair, getting rid of a continuously beeping parking sensor system is pretty rewarding! If you can be bothered, it would be great to see a how-to for some of the things you've got on your list to fix if you have the time ![]() -Oli
Andy. Current cars: BMW i4 M-Sport Peugeot 207 (the sons) Triumph Daytona 675 (2017 reg) =========================== Gone but not forgotten Ford Focus ST-2 Mk3 (the wifes) (stolen Oct 2023) 1972 T2 Bay Window Camper (Slow) Audi TT Mk1 225 - now with coil-overs and a 7inch touchscreen infotainment centre 2003 A8 Sport 4.2 (with ACC & LPG) (Feed up with all the issues so passed it on to a forum member) 2000 A8 FL QS 4.2 (with RNS-E - Nice ![]() |
I need to get the rear brakes done before the end of Jan so I'll have a 'How to' or 'How not to' by then closely followed by the front conversion. Yes, the Audi 8 pot calipers are on their way ![]() I know a couple of you have done the front conversion so if you have any tips let me know so it doesn't turn into the day from hell part 2 ![]() |
