Old 21st September 2010, 09:49 AM
woodshed woodshed is offline
Unhappy Help with brake part numbers please
Can anyone help?
I need the part no for front brake calipers for a 1996 3.7 with 314 mm discs. Engine code AEW if that helps.
The set from the breakers rattle worse than the original set!
Martin
Martin Wood
Rescue Helicopter Pilot
Work in Ireland - Home in Devon
Old 21st September 2010, 03:19 PM
4D0 615 107 A - Left
4D0 615 108 A - Right
I will have a set of these spare in a weeks time. Happy to swap with a bit of cash. PM me.
Old 22nd September 2010, 09:12 AM
Default Thanks for the help
Thanks for that. Not sure about another set of used ones! Both sets I have tried have so much movement on the sliding pins that I can move them by hand. Rattle is now driving me mad.
Martin
Martin Wood
Old 22nd September 2010, 01:04 PM
once you have the price of a new pair of calipers check back here. there are upgrade routes that may be worthwhile.
Old 22nd September 2010, 02:53 PM
I looked through my note book i had my caliper refurbed by a company called Transhock. He did say they only normally deal with trade, however it was £87.14 inc vat + £30 surcharge. £129.63 all in delivered and they refunded the £30 when they recived my old caliper.
Old 26th September 2010, 11:23 PM
Default Stumped trying to replace calipers
Thanks Dezzy
I have replaced the calipers with a used set (not from A8 parts) and they are worse than the first set. I can move them by hand. I have sent half a dozen e-mails to http://myworld.ebay.co.uk/vjscomponents/ who advertise new calipers for £135, but I cannot get them to reply to an e-mail asking them to confirm they are new rather than re-manufactured.
The only guys that I could find who remanufacture calipers were honest enough to let me know the set they were going to send me failed their pressure test and refunded my money. Fair play - but they can't get any more to try!
Although I am UK registered I work and keep the car in Ireland. The cost of sending calipers out here negates any returns or deposits. I have replaced all the ball joints and both sides still rattle over small high frequency bumps. The rattle stops at even the slightest touch of the brakes and i can rattle the calipers by hand. What else could it be?
Martin
Martin Wood
Old 27th September 2010, 06:30 AM
It could be that the outer pads are not stuck onto the carrier. The pads come with an adhesive pad that sticks them to them inside the slide so they don't rattle. If they are removed and put back people don't bother to get new double sided sticky pads.....
Old 27th September 2010, 08:34 PM
Oli18's Avatar
Oli18 Oli18 is offline
Mine rattle too as the stickyness has gone. Do you have a recommendation for new sticky tape by any chance?
Oli
Audi A8/S8 D2 Flickr Group
Old 27th September 2010, 09:16 PM
I use Copaslip on the back and edges.
Old 28th September 2010, 10:54 AM
I thought that the spring clips were there to stop the pads rattling. I have tried 3 different make of pads until I got one with the clips.
None of them have had double sided tape. As you have to slide the pads in -how do you get the tape to the right spot?
Martin Wood
