Hi all,
It's been a while since i've posted but i've kept an eye out on the forum and been enjoying the 8 in the meantime. For about 2-3 months now, I've been suffering from a parasatic battery drain which means that if the car is left for 2 weeks without driving, it struggles to start. If left a week, i also notice it's down but a bit better. Below is the last scan I did at the end of October which i was hoping might give a clue. I can't remember if i cleared the fault codes afterwards or not but i can do another scan later this week to check. I haven't changed the battery and am reluctant to do so without eliminating the other potential causes first and wanted to check what methodology others go through to find out where a drain might be coming from. For reference, the following are known to me: - TPMS has been disabled - Soft close driver handle stopped working a few years back - Rain sensor replaced in March - i can clear codes to see if it re-appears - Auxiliary parking heating has never worked - Driver identification component protection has always had this Your advice is greatly appreciated. Oli OBDeleven data log Date: 2016-10-30 10:47 VIN: WAUZZZ4E26N019357 Car: Audi A8 Year: 2006 Mileage: 206060 KM --------------------------------------------------------------- 02 Transmission Control Module System description: AG6 09E 4,2lTDI RdW Software version: 0030 Hardware number: 4E1910156P Serial number: 0076831 Coding: 0000001 Trouble codes: No trouble codes found --------------------------------------------------------------- 05 Kessy System description: FBS AUDID3 H10 Software version: 0190 Hardware number: 4E0910131 Serial number: AUX3Z0F0383869 Coding: 0412672 Subsystems: System description: ELV Software number: XXXXXXXXXXX Software version: XXXX Trouble codes: 00179 - Driver access/start authorization antenna Upper limit exceeded static 00668 - Vehicle voltage terminal 30 Lower limit not reached Intermittent --------------------------------------------------------------- 06 Seat Adjustment Passenger Side System description: Sitzmemory BFS H02 Software version: 0010 Hardware number: 4E0910760D Serial number: 5DS 008 795-03 Coding: 4063328 Trouble codes: 01725 - Longitud. adjustment switch, backward, driver seat mechanical malfunction Intermittent 01724 - Longit. adjust. switch, forward, frt. pass. seat mechanical malfunction Intermittent 01970 - Depth adjustment button, backward mechanical malfunction Intermittent 01969 - Depth adjustment button, forward mechanical malfunction Intermittent --------------------------------------------------------------- 07 Display Control Unit System description: Interfacebox H43 Software version: 5570 Hardware number: 4E0910769Q Serial number: 300AC067562505 Coding: 0000002 Subsystems: System description: Bedienteil MMI H42 Software number: 4E0910609A Software version: 0020 Trouble codes: No trouble codes found --------------------------------------------------------------- 08 Air Conditioning System description: KLIMAAUTOMAT 016 Software version: 0400 Hardware number: 4E0910043B Serial number: 00000000088042 Coding: 0022563 Trouble codes: No trouble codes found --------------------------------------------------------------- 09 Central Electrics System description: ILM Fahrer H14 Software version: 0230 Hardware number: 4E0910279Q Coding: 0133122 Subsystems: System description: Wischer WWS D3 H50 Software number: 4E2910113B Software version: 0420 Coding: 0000036 System description: REGENLICHTSENSORH11 Software number: 4E0910557 Software version: 0050 Coding: 0139548 Trouble codes: 01520 - Rain/light recognition sensor Lower limit not reached Intermittent --------------------------------------------------------------- 0E Media Player Position 1 System description: CD-Changer H44 Software version: 0470 Hardware number: 4E0910111F Serial number: AUZ5ZBF8049216 Trouble codes: No trouble codes found --------------------------------------------------------------- 11 Engine Control Module 2 System description: 4.2L V8TDI A000AGSª Software version: 0070 Hardware number: 4E1910409A Serial number: AUX3Z0F0383869 Coding: 0011773 Trouble codes: P1849 - Read DTC memory of transmission CM Implausible signal Intermittent --------------------------------------------------------------- 13 Adaptive Cruise Control System description: ABSTANDSREGELUNGH03 Software version: 0020 Hardware number: 4E0910561F Coding: 0011154 Trouble codes: 01316 - Brake control module Please read DTC Intermittent --------------------------------------------------------------- 15 Airbag System description: Airbag 9.41 H12 Software version: 3610 Hardware number: 4E0910655D Serial number: 0037P000DLH0 Coding: 0431707 Trouble codes: No trouble codes found --------------------------------------------------------------- 16 Steering Column Electronics System description: Lenksäulenmodul H13 Software version: 0040 Hardware number: 4E0910549 Coding: 0112151 Subsystems: System description: Lenkradmodul H07 Software number: XXXXXXXXXXX Software version: 0080 Trouble codes: No trouble codes found --------------------------------------------------------------- 17 Dash Board System description: KOMBIINSTR. VDO H70 Software version: 0410 Hardware number: 4E0910980N Serial number: AUDID3F0000091 Coding: 0000403 Trouble codes: 16346 - Control module Faulty static --------------------------------------------------------------- 18 Auxiliary Parking Heater System description: Heizgeraet H07 Software version: 0110 Hardware number: 4E0910105A Serial number: 00000009006406 Coding: 0000001 Trouble codes: 01412 - Glow plug with flame monitoring Implausible signal static 02251 - Heater unit locked static --------------------------------------------------------------- 19 Gateway System description: Gateway H11 Software version: 0090 Hardware number: 4E0910468B Serial number: 19004061088029 Long coding: FEFFFBDF2B7504 Trouble codes: 01325 - Tire Pressure Monitoring Control Module No signal/communication static 01044 - Control module incorrectly coded static 00467 - TV tuner No signal/communication Intermittent --------------------------------------------------------------- 1D Driver Identification System description: FPI_1 H06 Software version: 0060 Hardware number: 4E0910218 Serial number: 11082004063652 Trouble codes: 02095 - Component protection active static 00446 - Function limitation due to insufficient voltage Lower limit not reached Intermittent --------------------------------------------------------------- 1E Media Player Position 2 System description: SG ext.Player Software number: 4E0035785F Software version: 0850 Hardware number: 4E0035785C Hardware version: H20 Long coding: 010000 Trouble codes: No trouble codes found --------------------------------------------------------------- 25 Immobilizer System description: FBS AUDID3 H10 Software version: 0190 Hardware number: 4E0910131 Serial number: AUX3Z0F0383869 Coding: 0412672 Subsystems: System description: ELV Software number: XXXXXXXXXXX Software version: XXXX Trouble codes: 00179 - Driver access/start authorization antenna Upper limit exceeded static 00668 - Vehicle voltage terminal 30 Lower limit not reached Intermittent --------------------------------------------------------------- 34 Ride Control System System description: LUFTFDR.-CDC H06 Software version: 6310 Hardware number: 4E0910553J Coding: 0015510 Trouble codes: 01400 - Level control system Upper limit exceeded Intermittent 01398 - Signal wiring from central locking - doors open No signal/communication Intermittent 01772 - Sig. wire from level ctrl pressure sensor Implausible signal static 01577 - Switch-off due to excessive temperature Upper limit exceeded Intermittent --------------------------------------------------------------- 36 Seat Adjustment Driver Side System description: Sitzmemory FS H02 Software version: 0010 Hardware number: 4E0910760D Serial number: 5DS 008 795-03 Coding: 4063342 Trouble codes: No trouble codes found --------------------------------------------------------------- 37 Navigation System description: MNS ECE H47 Software version: 1060 Hardware number: 4E0910888P Serial number: 364AS067525548 Trouble codes: 02261 - Data medium Faulty Intermittent 02927 - DVD read error Intermittent
![]() CURRENT: 2006 Audi A8 D3 4.2 Tdi QS - CLICK HERE FOR PROJECT THREAD: Audi Exclusive Azure Blue, Amaretto brown interior, facelift rear lights, S8 mirrors, B&O, ACC, Digital TV, glass sunroof, Fridge, Extended Leather Pack 2, wooden steering wheel & gearknob, keyless entry, keyless start, electric boot, softclose doors SOLD : 2000 FL Silver D2 4.2 QS - Solar sunroof, Bose, Blinds, NavPlus, Playstation, DVD, wireless headphones, iPhone AV connection, RS6 steering wheel, chrome mirrors, phone prep, xenons, servotronic steering, Rear screen, TV-in-motion, NavPlus Alu rings, S8 exhaust, S8 bonnet grille, 385mm D3 S8 brakes, rubber winter mats, De-badged rear, US rear indicator clusters, 20" Final Edition diamond cut wheels, 15mm Eibach Pro spacers (front), 20mm H&R hubcentric spacers (rear). Audi A8/S8 D2 Flickr Group Last edited by Oli18; 28th November 2016 at 06:43 AM. |
Has the battery to your knowledge ever been changed?
If not I'd suggest it's just time, like tyres they really are a consumable. As the cold weather creeps in dying batteries start to show they are dying.
FYI in May I replaced my battery in my W12 with this one and been very happy with it.
http://www.ebay.co.uk/itm/Lucas-LP-0...EAAOSwfcVUIv1l
Hello Oli
wheres engine 1 in the scan , does it have battery regulation on the vehicle . Follow earth lead off the battery .....does it go to module before it terminates to earth . Could be a battery like already said ,but could also have a drain on it . Ideally you need to put a amps meter in series between the battery lead and see how much draw you have as the draw rate gives you a clue as to whatever may be staying awake or pulling low amps out |
One of the functions of the BEM is to cut off power rails when neccessary to preserve battery change. 2006 MY BEMs didn't suffer the problems of earlier ones.
I have had similar issues and fitted an AGM battery and recoded and only had problems since when leaving the ignition on by mistake. I don't think two weeks is that bad if it still starts (even reluctantly), afterall it has an alarm and keyless entry to run. I have also found that leaving VCDS plugged in when turning off the car and then unplugging it seems to cause a battery drain. Always close the controller and unplug while the ignition is still on now. |
Should battery energy monitor of been in the scan Snap ? .............. is on my car anyhow .....me leaving my auxillary burner going for to long often puts quiecent volts under codes in there ......cars is lovely and toasty in the morn though hehehe
Hmm... I have the same problem on my car and I'm watching this thread with interest.
Audi think it was caused by a faulty EPB motor. It's been changed now but I've not had the car back so I can test. |
Nope. I don't want to hijack this thread but Audi have been chasing a ridiculously minor knocking sound for a grand total of 13 weeks. I've called them today for an update and I'm waiting for them to get back to me.
There's many faults in there. I'd suspect quite a few of them are old and related to low battery but the one that jumps out to me is the over temp of the air compressor.
That tells me you quite possibly have a leak in the suspension somewhere. If there is a leak then the suspension will be trying to level it's self periodically while your away from the car. I don't know however if it will run the compressor or just use what's in the accumulator. The other thing that jumps out is the instrument cluster fault. It's vague but I have seen on two occasions now where a faulty cluster keeps the can bus awake while the car is locked and that flattens the battery. You can easily tell if the can bus is awake by looking to see if the lights around the gear shift are lit up at night when the car has been locked for more than 10 mins
Del ![]() Last edited by Delboy; 17th December 2016 at 06:26 PM. |
