D3 - Body and Exterior Bumpers, bonnets, glass, trims - Everything outside |
hi the audi has had a interment problem with the wipers when on for a period of time they would stop but when you pull the wiper stock to the stop position and then restart them they worked again.
But yesterday they have stopped working all together check fuse all ok is they any way of checking the motor or is there a relay its a 2004 audi a8 cheers trev |
Here's something to try. Go into the MMI and check under 'car setting'. See if there is an error message along the lines of 'reset windshield wipers maintenance'. If there is, clear it and see what happens.
The ECU and relays that control the wipers is part of the motor assembly.
I had to replace the whole thing on my 2004 a couple of years ago, its a right faff getting the assembly out and the new one installed. It looks easy, as the assembly is only held in place by a couple of bolts, but you soon find the bonnet, strut brace, brake servo are all in the way. I managed to do it, but you need to remove quiet a lot of parts to get it where you can wiggle the assembly out. Here is the thread where I swapped it out. http://forum.a8parts.co.uk/showthread.php?t=7936
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 20th March 2017 at 06:39 PM. |
Ok thanks for the information looks like the motor then cheers
