Old 15th September 2017, 07:12 AM
NLA is 'No Longer Available'. Sadly its becoming a common occurrence for D2-specific parts like hoses, trim etc. Even the little plastic arm for the headlight levelling now too - luckily yours is still serviceable.
Goran's car is a LHD manual, so if its leaking gear oil from the cooler lines there's a 50/50 chance the hose which is leaking is not available to buy any more. Being a manual, there aren't any secondhand either like there are for the autos. That would be a problem, were I not doing a RHD manual conversion in October, however since those hoses aren't available I will be developing an alternative solution
That's great! I'll hold on until October when you have the new solution
I'll get under the car at some point to try to see where its coming from.
Apologies for sidetracking the thread and causing confusion
