Big Red properly kicked my arse tonight, for the first time in this project. Pinch bolt time...
The first one thwarted all normal methods to get it out, so on to the extreme solution. Cut the head off the bolt at the first arm, and prep a half-washer ![]() Push the half washer in to the slot by the nut - it has to be a tight fit to avoid breaking the strut with what we're about to do next. Yes, I cut the control arms off. They were scrap, and in the way ![]() ![]() grease up the thread and stick a couple of chunky washers on the bolt and put the nut back on ![]() The theory at this point is that you start tightening up the nut and the force pulls the remains of the bolt out of the hole. Until tonight this technique had never failed me. This time the bolt snapped in the hole ![]() So, made up a 4mm pilot bushing ![]() and started drilling ![]() once I'd got a good pilot hole started I moved up to a 10mm drill ![]() After the 10mm got a fair way in I put it in the pillar drill to go the rest of the way through. I couldn't get a pic of that since I needed both hands. This is the stump which remained ![]() 2 hours to get one damn bolt out ![]() After that I made a tool to remove ABS sensors. One of Big Red's is bad, and I have two spare on my FE which I'm not using since that's getting alloy struts instead of the depleted uranium 20" versions. Start with some thick-wall alloy tube ![]() Turn it down to 17.5mm - just smaller than the sensor ![]() Trim to length ![]() Complete ![]() This is how it works ![]() ![]() ![]() |
