Old 28th July 2009, 08:54 PM
A8, mate!
Guest
Posts: n/a
Default Lowering a "non" Sport
One of the first things I plan on doing to my 4.2 is to lower it. I don't want it silly low, just lower than it is. The rear in particular on the non Sport car seems to ride rather high.
But what options have I got? I don't want to spend loads of money, but I'd like to do it right.
The obvious options seem to be a simple set of lowering springs (such as Eibach?) or perhaps fitting some second hand kit off a Sport or an S8.
Which is best, easiest etc? Are there any other options?
Thanks,
Adam
Old 28th July 2009, 10:30 PM
Oli18's Avatar
Oli18 Oli18 is offline
Hi Adam,
My 4.2 was a Quattro non-sport. I had A8 parts put the Sport springs on and put in the sports seats as i had them in my previous 8.
If you're happy with the 'sport' look then I'd suggest staying with OEM parts like this.
Any lower, and you're probably after a set of after market parts.
Good luck with it
-Oli
Audi A8/S8 D2 Flickr Group
Old 29th July 2009, 07:54 AM
AndrewGray AndrewGray is offline
Coilovers is the next move.
I'm running FK Coilovers and will soon be moving to air-ride.
I'll have my coilovers up for sale but I don't see it happening for another 4-5 months
Old 29th July 2009, 08:13 AM
A8, mate!
Guest
Posts: n/a
Oli18 - just springs yeah? Shocks are the same are they?
Did you have rear bench done too?
Old 29th July 2009, 09:27 AM
Hi Adam, yeah the back seats are diffrent on the sport too.
Old 29th July 2009, 02:41 PM
Hey A8, Mate so you are clear here are you options:
From non sport A8 you can fit sport suspension. User both springs and dampers, the reason will become clear in a moment.
You could fit a full S8 set up for 40mm of drop,
You can fit lowering springs, but be advised that with just springs your dampers are working out of their normal range and may fail earlier.
Finally there is a full after market set up which gives all the best options as they are generally adjustable at the front and some at the back to. Beware of the cheaper end of the market as the rebound is only adjustable off the car.
For immediate effect I would go the S8 replacement route as springs are 40mm lower and damper 40% uprated; and a full set is available at A8Parts!
HTH
