Old 24th January 2009, 10:32 PM
Default Cruise control not working
The cruise control failure is often just an underused stalk control. They frequently spend years not being used, and they seem to corrode over slightly on the contacts.
You often find that if you simply slide the switch on top back and forwards for a minute with some vigour, and press the button in and out a good number of times, it will start working. If this fails, it may be time to change the stalk over.
On prefacelift cars, it could be a perished pipe as the cruise system is the older 'sucking' system where a pump sucks the throttle in as required to achieve the speed desired. (you can feel the throttle moving beneath your feet) There is a mechanical failsafe as the tube used for the throttle pulling is physically terminated at the brake pedal. When the brake pedal is pressed, a valve opens and the pressure in the pipe is lost preventing the cruise system from artificially accelerating the car.
If there are any leaks in this pipe system, it will never pressurise and cruise can never function.
This doesnt affect facelift cars as they have electronic throttles, and all the cruise system is built into the ECU - The cruise stalk and its wiring to the ECU is the only possible cause of failure.
Old 31st January 2009, 09:59 PM
The cruise in my 'facelift' car is u/s too!
I specifically asked the vendor if it was working and he assured me it was. Are there any 'on' lights associated with it. It seems totally dead.
Old 1st February 2009, 09:35 AM
There are no lights, and on a facelift car, the stalk is the only component to cruise, so you've nothing to loose thrashing the buttons about vigourously trying to clean up the contacts. Alternative is a replacement stalk....
Old 1st February 2009, 10:11 AM
Not sure how it feels in the facelift, but in mine, you feel the pedal 'tighten' when you engage cruise.
Sometimes drops out when I try to increase the speed on the stalk, but a minor niggle.
Old 1st February 2009, 10:14 AM
The prefacelift had a mechnical cruise that physically moved the throttle cable, so you will feel the pedal move. This is normal.
Post facelift, its drive by wire, there is no throttle cable, so the pedal wont show any feedback. The cruise function is built into the engine ECU.
Its quite common for cruise to drop out when trying to increase speed, I've noticed it on a few cars, so you're not alone....
Old 1st February 2009, 06:04 PM
Oli18's Avatar
Oli18 Oli18 is offline
That's exactly what mine does...i just end up turning the cruise on, off but never using the increase speed function - when i do, it stops the cruise altogether.
I can't get the cruise to work again unless i turn of the ignition and restart the car again. It was never an issue though - it just meant you needed to avoid increasing the cruise speed!
-Oli
Audi A8/S8 D2 Flickr Group
Old 26th January 2013, 07:53 PM
Interesting, the cruise on my FL S8 is definitely a bit iffy and that seems to be the commonest symptom.
It worked fine on the test drive and bringing the car home.
Then in the very cold weather it hardly ever worked.
Now it's bit warmer it's in part-time mode and any operation of the speed change (up or down) can cause it to drop out.
I guess I'll be out tomorrow to attack the switch with the cleaning fluid.........
(no box to change on this one)
