Old 1st December 2009, 05:50 PM
MyA8
Guest
Posts: n/a
Angry Battery drain
Hello there, my electrical problems continue to frustrate me! Although I am finally getting to grips with various ABS, oil level sensor type warning lights I am now experiencing a battery drain which has started recently when the car is left for more than a day or two.
It seems a bit of a coincidence that since the weather has turned it lets me down. Ever since I've had this car its had some sort of electrical issue and the radio still goes dead every other day and requires me to disconnect the battery and restart/reboot the engine. The battery is new with good connection.
I am beginning to think that all roads lead to Rome but want to avoid various diversions to correct the fault.
I am losing patience. That said I love the car!
Any advice appreciated. I will post a pic when I get a chance.
Old 1st December 2009, 06:52 PM
Oli18's Avatar
Oli18 Oli18 is offline
Hi mate,
Have you got Vag-com? - it might help shed some light on any open circuits perhaps.
-Oli
Audi A8/S8 D2 Flickr Group
Old 1st December 2009, 06:58 PM
entwisi
Guest
Posts: n/a
check the alternator output, should be ~ 14.5V with the engine running, on mine ( where teh alternator had recently gone) when we disconnected the battery it dropped to 8-12 V)
There is also a connector on one of the chassis legs that I believe gets all corroded up. Check its all clean and good.
Are you SURE teh battery is good, I had similar when my battery was dying, clock resetting, sometimes starting fine other times wouldn;t even turn over and irrespective of how long it had been running or even how long since I'd turned it off.
Old 1st December 2009, 09:51 PM
This is the time of year when old batteries die... I'd get it checked over, especialy if it's a few years old.
Old 30th March 2010, 01:23 PM
A8 Doc A8 Doc is offline
I think you have a fault with the Battery module in all honesty...
Old 16th March 2014, 10:37 PM
a8starr a8starr is offline
I am starting to wonder if my car has an insuffeicient battery. On eurocarparts there is a choice between an exide standard which I believe I have. Cost me £70/80 from the independent. http://www.eurocarparts.com/ecp/c/Au...697000f&000020
and also this battery. exide premium which says its for cars with more electrical equipment.
http://www.eurocarparts.com/ecp/c/Au...fbfd7ed&000020
Since my new cheap battery in 2012 (it was coded) I have had slow cranking and battery drain issues. By battery drain issues I mean if sat in the car without engine running and some electrics on a battery warning light comes on. This is my battery
I remember audi quoting me £300 for a battery. I am sure audi supply Bosch batterys.
Whats everyones opinion on battery brands and going for OEM rather than cheap?
Old 17th March 2014, 10:06 PM
i agree with doc, you need a vcds check to see what software you have in the BEM as a starter
