Fortunatley I have an old version of Rosstech VCDS that I had for a previous car
Thought I'd fire it up and see what it could pull from the S8 results below Wednesday,31,October,2018,05:22:27:33490 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.3.0 (x64) Data version: 20140905 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4D (4D - Audi A8 D2 (1994 > 2003)) Scan: 25 01 03 08 11 15 16 17 18 35 37 45 55 56 57 65 67 75 76 77 02 ------------------------------------------------------------------------------- Address 01: Engine Labels: 4D0-907-560-AVP.lbl Part No: 4D0 907 559 AA Component: 4.2L V8/5V G 0002 Coding: 10753 Shop #: WSC 02314 VCID: 6DD7BFEF27132C7640B-5072 WAUZZZ4D33N000903 AUZ7Z0A2018570 No fault code found. Readiness: 0000 1101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8D0-907-389.lbl Part No: 4D0 907 389 E Component: ABS/ESP allrad D57 Coding: 08397 Shop #: WSC 02313 VCID: 316F639FFBAB8896243-50E6 2 Faults Found: 01119 - Gear Recognition Signal 35-10 - - - Intermittent 18264 - Throttle Potentiometer (G69) P1856 - 35-10 - Error Message from ECU - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No: 4D0 ö4D 0 Component: 4öö4D0820043Q Shop #: A8-öA8-K VCID: 8303795791974A0606F-2566 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4D0-959-655-AI8.lbl Part No: 4D0 959 655 T Component: Airbag Front+Kopf 5001 Coding: 01417 Shop #: WSC 02313 VCID: 4383395751170A06C6F-5072 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4D0-919-033-MYX.lbl Part No: 4D0 919 035 BA Component: KOMBI+WEGFAHRS.VDO D39 Coding: 00483 Shop #: WSC 56076 VCID: 66C5C0C302E51F2E011-5072 WAUZZZ4D33N000903 AUZ7Z0A2018570 No fault code found. ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8L0 862 257 P Component: CV-Pump, Alarm, RC D17 Coding: 15179 Shop #: WSC 02314 VCID: 428D3C534E0D030ECD9-4E42 7 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 00991 - Interior Lights 28-00 - Short to Plus 00955 - Key 1 09-00 - Adaptation Limit Surpassed 01134 - Alarm Horn (H12) 49-00 - No Communications ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl Part No: 4D0 035 192 M Component: RNS 4.2 H06 BNO 0102 VCID: 295F8BFFD37BF056EC3-4A3A No fault code found. ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: VCID: 55A7F70FAC8384B698B-5072 ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4Z7-907-357.lbl Part No: 4Z7 907 357 Component: dynamische LWR D07 Coding: 00001 Shop #: WSC 00000 VCID: 0401FA4B1499CD3EBF5-4A9C No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4B0-035-192-RNSD-56.lbl Part No: 4D0 035 192 M Component: Radio BNO 0001 Coding: 00207 Shop #: WSC 00216 VCID: 295F8BFFD37BF056EC3-4A3A No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4D0-919-283.lbl Part No: 4D0 919 283 Component: Parkingsystem A8 RDW D07 Coding: 01108 Shop #: WSC 00000 VCID: E8D94EFB88F1895EB3D-50E6 2 Faults Found: 01548 - Sensor for Parking Aid; Rear Right (G206) 30-00 - Open or Short to Plus 01629 - Sensor for Parking-Aid; Front Left (G255) 30-10 - Open or Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01L-927-156.lbl Part No: 4D0 927 156 EC Component: AG5 01L 4.2l5V RdW 1010 Coding: 00101 Shop #: WSC 02314 VCID: 6ED5B8E32A15D76E791-50E6 1 Fault Found: 18265 - Load Signal P1857 - 35-10 - Error Message from ECU - Intermittent End --------------------------------------------------------------------- I'm not too worried about Address 35: Centr. Locks Labels: 8D0-862-257.lbl as I'm pretty sure they were all related to my fannying around with getting the keys to work when I first got it. For the other codes though any suggestions on likely causes? I'm tempted to clear them all and see what comes back as I have no idea how recent they are and if any faults are still present. all thoughts appreciated? |
You've saved the current log, so do exactly that. If you choose the option to clear ALL DTCs, it may be worthwhile double-checking those addresses that had the faults to ensure they were cleared properly. After that, drive the car for a bit and then re-scan, and work from there.
I always go into each controller to clear the errors, the global clear isn't always reliable; and check afterwards by running another scan.
thanks chaps I'll shall clear and see what comes back
