Old 31st January 2021, 06:37 PM
jonnypym123 jonnypym123 is offline
Default Audi A8 D3 rear tail light bolt caps/covers
Hi guys does anyone know either the part number or where I can get the rear tail light bolt caps/cover?
I have a bit of a condensation freezing issue inside the car and think it might be coming through these as there all off in my car. Checked the carpets already near the hvac drain and the pipes are dry jist in case it was that.
Old 31st January 2021, 06:57 PM
homer simpson's Avatar
Are these part of the rear light assembly? Can't see it in pics
They look like the screw covers for the boot lid tool box
Old 31st January 2021, 08:06 PM
If those are indeed the light mounting bolt hole covers in your picture, then the chances are that your rear lights have been off. And the seating/seal of the light units are a more likely cause of any water ingress in the boot than the bolt hole covers.
Old 31st January 2021, 08:18 PM
Thants gents the picture is stock from when I googled them, the circular covers I'm looking for are the ones in this photo to the right near the boot seal, I'll be checking the seals tomorrow. Nie on impossible to find the caps/covers on the internet
Old 1st February 2021, 12:24 AM
They are just a screw covers, nothing to do with water ingress.
Also there are no seals for wing lights other than grommet on the cable and paper on the nuts. More likely to be something on the boot lid letting water in
Old 1st February 2021, 01:16 PM
It won't help with the water ingress issue, but the part number for the covers is 4E0863283. However, the price is £7 and that might be 'each'.
Old 5th February 2021, 08:44 PM
That's a steal at £7 a piece haha, some crazy prices but I might just have to get them cheers for the part number. I did some digging in the boot to try and find the problem, the outer tail light seal wasn't set right (I resealed the light few months back). Another thing it could be I had the windscreen replaced last May by autoglass due to a crack and since then I had condesation in the car and really noticed it more last few weeks freezing over inside. I had autoglass refit it in January and the fitter noticed it hadn't bonded at the top but still have the issue, getting them out again to check, no wet carpets so I'm guessing it's still the windscreen.
Old 30th March 2021, 08:48 PM
Have you checked the drain channels down the sides of the boot opening? The ones that accumulate leaf debris and sycamore seeds for fun? They have a join in them (what a daft design) and mine looked like it would let water into the join. I sealed it with Gorilla glue just to be sure.
Old 12th April 2021, 08:37 PM
Hi Jimster that's another job I need to do clean the muck out of the channels kind of been putting it off haha. But your right worth tending to before it comes a problem. Since the leak from windscreen I lifted the carpet and it was full of mositure straight to the tip it went and a new one in. Worth checking seals every year isn't it
