Old 24th July 2010, 10:19 PM
alefustec
Guest
Posts: n/a
Default Need some help on connecting up a TV tuner to run an IPOD and digital TV..
Hi all,
I know there have been lots of posts on this subject, and I have tried to work it all out but admit I'm still a bit clueless....so would be really grateful if someone could answer these questions;
1. I have bose, but no TV tuner, so ordered one from A8 Parts........great and apparently this will enable an IPOD connection, but I want to run the IPOD connection into the arm rest where the phone is. Ideally I want to replace the phone cradle to hold an IPOD, with the connections (including enabling it to charge) coming from the same connection point where the phone currenty is.....is this doable?
2. I assume the tuner also lets me watch TV, but I'm guessing analogue - what do I need to get a digital reception and how do you go about allowing the TV to be on whilst driving.
Apologies for the probably stupid questions but I really have no clue...
Old 24th July 2010, 10:52 PM
Have a look through these you may find what you need.
Here is a photo of mkoneman's install..........
Old 26th July 2010, 03:11 PM
alefustec
Guest
Posts: n/a
Brilliant - thats exactly what I'm looking to do, I'll take another trawl thru the threads and see if I can work it out.
Old 26th July 2010, 04:57 PM
Oli18's Avatar
Oli18 Oli18 is offline
Just a quick word of advice to avoid the dreaded 'Alternator whine'..
...for those that have run amplified installs before will know this.
For those of you who are lucky enough never to have been exposed to alternator whine, it sounds like a miniature siren that rises in pitch with the speed of the engine. Alternator whine is almost always caused by a ground loop.
Be sure to test your ipod sound before you put the interior back together ... i would test it at each stage of putting the interior back together by revving the engine whilst it's playing.
This should make sure it doesn't come up midway re-assemby.
I have this mod and it's brilliant so good luck!
Oli
Audi A8/S8 D2 Flickr Group
Old 26th July 2010, 05:14 PM
Mr K Mr K is offline
I have my iphone mount where james has his ipod and have routed the apple 'composite TV lead' through my car. I took a ton of pics as i worked so there should be a few "how to guides" soon - but it sounds like you have it all under control. I havent quite finished my apply tv install yet (still to sort the USB power - orderd the last few bits today) but ive had the phone lead hooked up for a few months now.
My phone mount (launcher) is broken i think - as when the arm wrest gets to a certain point it comes out at warp speed, firing my phone into the passenger footwell. I assume its meant to be damped?
Old 26th July 2010, 09:54 PM
alefustec
Guest
Posts: n/a
I recall reading one of the threads that mentioned the "alternator whine" but didn't really understand.........I still don't really (electrics of any description simply confuses me - my wife worries if I even wire a plug up), however, the main thing is I now know to check and sort it before putting the entire car insides back together, so thanks!!!
Old 26th July 2010, 10:01 PM
alefustec
Guest
Posts: n/a
Sounds broken to me......mine flips out when the rest is at about 45 degrees, I have to say its 'energetic' (hilarious when a passenger first noses inside to see whats there!), but it doesn't fly across the car. I was wondering as a neat mod, that when sorting the Ipod connection out that I could 'damp' the action so it sort of just glides out in a far more civilised manner..........I was even thinking (bear with me on this) that some sort of 'soft close' mechanism you get on furniture could be used to replace the spring?
