Hi,
I haven't used my car in about a week and i tried opening it today with the remotes (2 of them) but alas the car battery is flat somehow. i have tried opening it manually through the bootlock to get to the battery but something appears to be jammed in there and i can only put the key in half way. I have no ski-hatch as the rear entertainment unit is bolted in and the button by the drivers door doesn't work as it runs off the electrics. So, is there another option? I know on Volvos the battery is also in the boot but they have 2 points under the bonnet which allow you to jump start it from there...anyone know if we have that in our D2's by any chance? Thanks for your help..hoping i won't be needing the AA in the morning ![]() Oli
I don't think the D2 has them charge points, I left something on and the battery went flat and the AA guy was hoping that there was but ended up having to remove the invertor/DVD changer. He was asking why the feck I had one in my car I just acted dumb and clueless.
Oli, may be worth trying this? http://mobile.maplin.co.uk/module.as...c=so&u=strat15
Thanks Amar.
A few more questions if you don't mind... - is it possible to remove the entertainment unit from inside the cabin? - what was it the AA man did when you did get it out? It's quite a small area so just wondering how that allowed you to open the boot... - That Maplins link goes to their homepage. Would you mind reposting? Cheers buddy! Oli
I've never really fancied drawing starting current through the cigar lighter - or is that 12v auxiliary power these days - but a gadget this this may give you enough juice to open the boot. D2 does not need ignition for this socket to be 'live' so might be of use with a completely flat battery.
Link
D2 FL Q 2.8 V6 2002 Taxi(?) spec - no heated seats headlight washers etc. D2 PF Q 2.5 tdi LHD rear blinds and heated rear seats, Bose, 5 speed Tip, Servotronic, Pioneer AVIC 333,333 km Murdered on a P&O ferry 2012. Cat3 write off Last edited by christhompson; 9th January 2011 at 08:19 AM. Reason: More detail |
Can you believe i actually have a booster pack that allows this already with a cigarette plug? ... i'll give you 3 guesses where i keep this but you'll probably only need 1 after the following clue... ...it is currently not accessible! ![]() Thanks again! Oli
![]() CURRENT: 2006 Audi A8 D3 4.2 Tdi QS - CLICK HERE FOR PROJECT THREAD: Audi Exclusive Azure Blue, Amaretto brown interior, facelift rear lights, S8 mirrors, B&O, ACC, Digital TV, glass sunroof, Fridge, Extended Leather Pack 2, wooden steering wheel & gearknob, keyless entry, keyless start, electric boot, softclose doors SOLD : 2000 FL Silver D2 4.2 QS - Solar sunroof, Bose, Blinds, NavPlus, Playstation, DVD, wireless headphones, iPhone AV connection, RS6 steering wheel, chrome mirrors, phone prep, xenons, servotronic steering, Rear screen, TV-in-motion, NavPlus Alu rings, S8 exhaust, S8 bonnet grille, 385mm D3 S8 brakes, rubber winter mats, De-badged rear, US rear indicator clusters, 20" Final Edition diamond cut wheels, 15mm Eibach Pro spacers (front), 20mm H&R hubcentric spacers (rear). Audi A8/S8 D2 Flickr Group Last edited by Oli18; 9th January 2011 at 08:39 AM. |
Are the locks not just frozen up? May also be worth trying to get in the drivers door to see if the internal electric boot release has enough juice in it to work. If not then something plugged in to give some charge should give enough power for the solenoid to function
Tech tip 1
![]() Check your boot lock regularly! I wouldn't want to do a jump with one of those lighter units attached (especially seeing as the lighter sockets are rated at 10A), but should be enough to get a little bit of power in there to open the boot.
