Old 25th January 2016, 12:34 PM
I don't know if the heater was dropped from MY2005 because it's now integrated with the Radar??
Have you VCDS? Is the ACC heater disabled in module 13 - Distance Regulation adaptation channel 3?
Prochitat zdes
http://www.audi-portal.com/ru/diagnostic/ecu_11716.html
Matt
Old 25th January 2016, 02:51 PM
andydls andydls is offline
Prochitat zdes
thanks for the advice! We need to study it in more detail. Let you know later ..
Old 25th January 2016, 04:24 PM
mannyo mannyo is offline
My 2004 model with factory fitted ACC does not have an external heater.
Manny
Past
Old 28th January 2016, 10:24 AM
All 4E0 907 561 F without heating!
Old 28th January 2016, 09:10 PM
A chto zhe drugiye delayut v takikh usloviyakh? V Anglii eto ne problema
Matt
Old 2nd March 2018, 08:56 PM
neeldub neeldub is offline
Can you have ACC alongside Side Assist?
Would the 4E0 907 468 H CAN Gateway support both functions?
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 22nd April 2023, 12:57 PM
Versace Versace is offline
Is it possible to do a retrofit but with cluster/speedo without the red LEDīs? I do have the "widescreen" speedo but obviously without the LEDīs for the ACC.
I do have an ACC speedo, but it does not help, its for an A8 4.2 and I would like to retrofit it in an S8.
FYI: The 2008 A6 C6 does have an external heater element to heat the grill plate/cover of an ACC.
S8 D3 FL II.
Porsche Cayenne 958 Turbo
BMW E83 X3 3.0d M-Sport
Old 1st May 2023, 04:23 PM
Not sure about retrofitting ACC without the correct cluster, but I have two clusters that may or may not be of use to you, depending on exactly what you want. Your signature says you have a 4.2 but you say you want to install it in a S8, so I'm a bit confused.
I have a standard widescreen S8 cluster that I removed from my S8 when doing the ACC retrofit.
I also have a widescreen ACC cluster that came out of a W12 D3 from A8parts, when I got all the other necessary parts, but hung on until I got the S8 ACC cluster.
I have photos of them somewhere with part numbers, so will post them up when I find them.
EDIT: Well that was easier that I thought. I actually advertised them for sale ages ago on the forum, with all the relevant information. They can be found at these links:
S8 Facelift Cluster
A8 Facelift ACC Cluster
Last edited by steamship; 1st May 2023 at 04:27 PM. Reason: Links to Ads with Photos
