Old 1st June 2021, 02:26 PM
homer simpson's Avatar
I have built a magic box to simplify the process of spinning the engine to get oil pressure while its on the separating table. It plugs in to the oil pressure switch, has a couple of flying leads to connect to a battery, and the starter cables attach to the right hand side. The red button is a switch which lights up when it has power
Press the switch to activate the starter, and the green light comes on when there is oil pressure
Simple but genius!
Old 1st June 2021, 06:14 PM
Gearbox next. As usual, I will flip it over to get to the sump and filter, however normally when I do that the diffs are drained ready for re-sealing. This one though is not leaking and so I'm not touching the output flanges and not draining the diffs. That means that if I flip it over, the gear oil will all leak out of these breather holes:
Hi MJ, Is there a process posted where the diffs are refilled? I assume you don't use the breather holes for this?
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 1st June 2021, 07:43 PM
I may have shown it in a previous WITW. There's a fill plug on the front diff, right hand side in front of the output flange. The centre diff has a fill plug halfway up the rear casing, also on the right hand side a few inches in front of the end of the box. Thats a bit harder to reach with the engine in as the cat is in the way.
Old 3rd June 2021, 08:17 PM
I fitted the lower control arms and driveshafts on to the subframe earlier in the week. This makes everything much easier to put back together.
This evening I removed the front suspension
Potato-cam picture sorry Struts and lower arms removed and broken down as much as I can. I'll make a start on the seized pinch bolts and track rod ends tomorrow. These will probably be a couple of hours each as they are properly stuck.
ID:	26527   Click image for larger version
ID:	26528   Click image for larger version
Old 4th June 2021, 09:13 PM
A pleasant surprise with the suspension - the tie rod ends wouldn't budge on the car and I didn't even bother trying the pinch bolts. Once I had the uprights in the vice and could get some proper force on them everything just came apart without a fight I had both stripped in an hour.
I started cleaning the engine bay and vaccuming out the detritus from the scuttle. There was quite a lot!
Cleaned up around the ECU box so I can do Botang's hole in the morning. You can also see the two new connectors to repair the wiring harness. These are from Sergey's car, the parts from which continue to keep the others going.
ID:	26534   Click image for larger version
ID:	26535   Click image for larger version
Old 4th June 2021, 09:27 PM
Markiii Markiii is offline
MJ could you take some pics of botangs hole, I've never really got my head around where it is
Old 4th June 2021, 09:43 PM
Ronin Ronin is offline
Hmm,my FL A8 also has steel front uprights and it doesn't have those screws that hold the discs down.. strange
Old 4th June 2021, 09:47 PM
No longitudinal Audis (of this era) have screws holding the brake discs on, for no obvious reason. Golf-derived models like the A3 and TT have them. More expensive / upmarket models just have the discs fall on the floor when you take the caliper off
Old 5th June 2021, 09:34 AM
Mark, check out the following post by MJ:
http://forum.a8parts.co.uk/showpost....2&postcount=16
Old 5th June 2021, 09:10 PM
The tape is intact but beginning to peel so I'll fix it permanently while access is less difficult than normal
Zoomed out view
Peel the tape off with a pick - its not leaking yet, but its only a matter of time
The hole
An out-of-focus plastic rivet
Pushed in to the hole with some seam sealer
and covered over with more seam sealer
On to the wiring harness. Previously spliced wires on the left, replacement connectors on the right.
Crimped and heat-shrunk
Some Tesa tape to act as a strain relief and to stop them rattling
Wires tucked away and the connectors back in place
Then cleaned the engine bay
I did the other side too, but forgot to take any pics. A little more tidying underneath in the morning and then the engine can go back in
ID:	26538   Click image for larger version
ID:	26539   Click image for larger version
ID:	26540   Click image for larger version
ID:	26541   Click image for larger version
ID:	26542   Click image for larger version
ID:	26543   Click image for larger version
ID:	26544   Click image for larger version
ID:	26545   Click image for larger version
ID:	26546   Click image for larger version
ID:	26548   Click image for larger version
ID:	26549   Click image for larger version
ID:	26550   Click image for larger version
