Old 21st December 2013, 06:53 AM
Oli18's Avatar
Oli18 Oli18 is offline
Default Adding AV cables to digital tuner
Hi,
So my MMI says I have 2 more AV channels alongside 'TV' and 'Interface'.
Does anyone know what cable I need for the digital tuner to be able to run an AV cable into the cabin? I'd like to be able to play videos off my iphone/iPad (I have the composite cable already).
Thanks,
Oli
Audi A8/S8 D2 Flickr Group
Old 21st December 2013, 07:25 AM
http://www.ebay.co.uk/itm/CT29AU02-A...-/160690745278
Then RCA extention cables from the TV tuner to wherever you want the AUX...
Old 21st December 2013, 07:51 AM
Oli18's Avatar
Thanks Snapdragon! Just ordered
Do you know how easy is it to wire into the tuner?
Thanks again,
Oli
Old 21st December 2013, 02:21 PM
http://www.audi-resource.com/retro-aux.php
This should help, its easy but fiddly.
Old 11th January 2014, 06:22 AM
Oli18's Avatar
Thanks guys,
The instructions on the site show that each AUX IN has 5 pins:
But I have six pins in total on the cable.
Any advice?
Also I assume that red = audio, black =audio and blue = video?
Many thanks,
Oli
Old 11th January 2014, 08:42 AM
Ah.. They're not the cable for the D3.
Both Audio connections have a common "-" connection. can't really tell from the pic, but if you can open up the connectors and put two of them together into the one, then that'll sort you out.
As to the colours, doesn't really matter too much, but that's the usual convention.
