Old 3rd February 2016, 09:36 PM
carmel120 carmel120 is offline
The worst that could happen is you brick the unit, if that happens ebay is full of them for reasonable money these days and you could always buy my S8 one that I have for sale
https://flic.kr/s/aHskouH8Tt
pm sent
Old 19th May 2016, 12:39 PM
gotman25 gotman25 is offline
Thanks guys for the post. My old cluster with small FIS is playing up. Decided to replace with wide FIS and ordered.
Looks, is really simple job.
I don't have problem with millage correction, can adjust myself. It takes 10sec
Old 1st February 2017, 03:15 PM
magichow magichow is offline
hello, I want to change a little FIS at large. if we can only change the display?
Old 1st February 2017, 03:38 PM
No, you can't resolder a large screen in place of the small screen.
There is a thread on Audiworld where one user discovered that newer small screen DIS are actually a masked large screen, they then flashed with the correct firmware to make it work!
So, it depends what year and cluster you have. Can you post a VCDS scan of your current cluster. The simplistic route is a direct swap.
Matt
Old 1st February 2017, 03:49 PM
is me just replacing the instrument cluster and lock CP?
Old 1st February 2017, 03:53 PM
Yes, CP will kick in. It can be removed from a main dealer or Indy with GeKo access for a fee.
Matt
Old 21st June 2019, 08:44 AM
IT D3 IT D3 is offline
Reviving an old thread here - does anyone know if a later widescreen cluster 3g and be retrofitted to a car with 2g MMi High?
Contemplating this upgrade but wasn't sure on compatibility
Old 21st June 2019, 09:04 PM
I think this is what I have - it was from a 2008 facelift into my 2006.
4E0 920 951 J
The backlighting is slightly nicer on the later ones and has a digital speedo option (which you can also set to KM/h).
Old 21st June 2019, 11:50 PM
H-M3 H-M3 is offline
This was on my to do list, the cluster is still in my boot.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 15th July 2019, 01:53 PM
4E0 920 951 J
Thanks snapdragon, so you fitted a widescreen cluster off a 3G A8 without any issues then?
I did have a chat with marcin about this before and he said I need a 2G cluster hence why I was confused...
