#61
#62
Thanks guys for the post. My old cluster with small FIS is playing up. Decided to replace with wide FIS and ordered.
Looks, is really simple job. I don't have problem with millage correction, can adjust myself. It takes 10sec ![]() |
#63
hello, I want to change a little FIS at large. if we can only change the display?
#64
There is a thread on Audiworld where one user discovered that newer small screen DIS are actually a masked large screen, they then flashed with the correct firmware to make it work! So, it depends what year and cluster you have. Can you post a VCDS scan of your current cluster. The simplistic route is a direct swap.
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 1st February 2017 at 03:43 PM. |
#65
is me just replacing the instrument cluster and lock CP?
#66
Yes, CP will kick in. It can be removed from a main dealer or Indy with GeKo access for a fee.
#67
Reviving an old thread here - does anyone know if a later widescreen cluster 3g and be retrofitted to a car with 2g MMi High?
Contemplating this upgrade but wasn't sure on compatibility ![]() |
#68
I think this is what I have - it was from a 2008 facelift into my 2006.
4E0 920 951 J The backlighting is slightly nicer on the later ones and has a digital speedo option (which you can also set to KM/h). Last edited by snapdragon; 22nd June 2019 at 11:55 AM. |
#69
#70
I did have a chat with marcin about this before and he said I need a 2G cluster hence why I was confused... |
