Old 5th April 2016, 12:53 AM
H-M3 H-M3 is offline
Default pdc Again!
After with the help of marcin I managed to sort out my front sensor issues few weeks back. Now the problem has re-occurred but slightly different. When I put it in reverse the graphics show as if I am very close to hitting something on the both rear sensors, with the constant beep!!! argh Is that sensor or the actual unit? please help. How hard is it to change the rear sensors?
cheers
Old 5th April 2016, 05:34 AM
sounds like sensor, vcsd will be able to tell you which one
Old 5th April 2016, 02:56 PM
thanks. Is it a bumper off job for the rear sensors too? or can they be accessed via under the car without?
thnx
Old 8th April 2016, 06:51 AM
Oli18's Avatar
Oli18 Oli18 is offline
Hi,
I believe it's a bumper off job.
You can often tell which sensor it is without VCDS by doing the following:
- turn on parking sensor
- walk around the back and touch each sensor
- all working sensors tend to have a slight 'click' to them that you can feel by touching them if they detect movement
- any sensors that are broken usually don't have this
Good luck
Oli
Audi A8/S8 D2 Flickr Group
Old 8th April 2016, 09:07 AM
You can do the rear by removing a support screw or two at the bottom of the bumper so you can flex it a bit. Still bit fiddly though.
Old 8th April 2016, 12:24 PM
Cheers guys, gonna see my lovely friend and Guru Marcin hopefully tomorrow so will get his eagle eye experience and expert advice
