Old 1st June 2016, 10:00 AM
Jim, you're more than welcome to have the bits. I don't want anything for them.
I don't have any of the foam sheet though, only a the Nassboard and a roll of the foam tape, of which I can cut you a couple of metres or so off.
The remaining Nassboard is 600mm wide and just a little over 800mm long, so enough to make a couple of covers. It may cost nearly as much to post that as it does to buy a sheet though (£8.49, inc delivery) so I'm wondering if maybe there's someone from your neck of the woods going to the meet this weekend who would be willing to take it back for you? I could cut it in half so that it's not so unwieldy. The piece I used was less than 400mm high so cut down the middle, each half should still be more than large enough to make a cover.
