Old 23rd May 2016, 06:24 PM
Someone has to ask these awkward questions Mark And what do you know, they don't post to Northern Ireland.
However, as you say, there are others selling it as well, so it gives me somewhere to start looking. Thanks.
No problem. What you're looking for is neoprene sponge/foam sheet. Check that it's 'closed cell' (ie doesn't absorb water) and that it can be glued (if not buying the self-adhesive stuff).
The image in the ebay listing I posted is misleading, making it look like a rough foam. It's actually very smooth/soft to touch, with a fine/small cell structure, similar to the original foam backing.
EDIT: If you can't find a seller who delivers it to NI, let me know, I can order some for you and bring it to the meet (assuming you're going).
Old 23rd May 2016, 06:46 PM
Cheers Mark, but had to cancel the annual meet this year. It was either that or the 'ExplorA8tion Ireland!' one.
Managed to find ones that supply to Northern Ireland, so all the bits ordered. That's yet another little job to do to the car now
Old 23rd May 2016, 08:18 PM
Excellent.
Old 1st June 2016, 06:13 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Superb job! Its on my list of to do when i get 5 min projects.
Only downside is that my template is mush and came out of the car in handfulls, not one piece.
Ive got the foam backing in one piece which should give me enough of a template to work with.
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 13th June 2016, 08:44 PM
Ameiseuk's Avatar
Default Another job off the list
Rotten footwell board replaced....
One off the list
Daily drive:
Current 'Project':
2000 Audi S8 FL
www.whall.co.uk
Old 14th June 2016, 07:21 AM
One off the list
Nicely done!
Old 17th June 2016, 11:31 AM
I've got a lovely one from Steamship, just need to find time to fit it.
Old 22nd June 2016, 10:18 AM
Finally managed to get my own one done yesterday between the showers, and a big thanks to Mark for telling us how he did his
Old 25th May 2016, 05:11 PM
Looks like the problem is solved anyway, but remember a group of us are travelling on from the Annual Meet to Ireland, if anything needs bringing over.
Old 25th May 2016, 08:51 PM
Thanks for the consideration Andrew, but at 1200mm x 600mm, it would take up a good bit of space.
In the end, the supplier cancelled the order as TNT wanted a further £28 to post it, with no guarantee it would arrive in one piece. No issue, as I've now ordered it locally.
