Quite right - There are quite a few modules missing aren't there? Park Brake, Parking sensors, Engine, ABS, Radio, BOSE DSP( if fitted) Battery Manager etc...
The LEDs on the tops of the door cards that flash red - are they supposed to flash constantly?
Mine seem to slow to flash only once every 10 seconds or so, maybe longer (my memory is fading!). Does that mean the car is gone into low-power, battery conservation mode, or is it normal? Oli, what do your LEDs do? |
I've had what appears to battery drains for over 4 years with my 2005 3.0TDi A8. Mine's still not fully sorted but my advice would be to :
1) Clear out all the faults/DTCs so you know what is actually currently faulty on the car. I'm not sure much reveals itself with a scan when there's a battery drain anyway, but you've got too many faults in your scan to see what might be going on currently! Not sure why you haven't got ECUs 1 [Engine], 3 [ABS], or anything above ECU 37 in your log. The most useful to see would be the Battery Manager [BM] ECU - 61. BM DTCs might be useful and some SW versions of the ECU are buggy and should have an update. [BTW; as well as missing some key ECUs, your logs seem to incorrectly identify Software levels as Hardware levels]. 2) Fully charge you battery with a smart charger. You can do this on the car without disconnecting anything but do it across the battery positive and the negative 'bar' connected to the BM. Will take about 10 hours - best done overnight. When charged fully, that is with the smart charger 'bulk' and 'topping' charge, battery volts with a voltmeter should be about 12.6V. Note - I'm not sure the BM that all A8s have correctly allows the battery to be properly 'fully charged'. Audi don't publish any specs. for the BM, so it's difficult to determine if it's charging with the 'bulk and topping' charge that lead acid batteries need now and then. 3) Check the battery volts with a voltmeter now and then. I bought one of those LED display voltmeters that plug in to the cigarette lighter socket. These aren't super accurate but you're checking voltage changes rather than actual values. Leave it in the front socket all the time and you can check the battery voltage by just looking through the window. [I left it in while I was away in Italy for the week and got my neighbour to look each night when it was dark so he could see it easily. On that ocassion I got virtually no voltage drop all week - went down about .1 Volts.] Bear in mind that approximately, 100% is 12.6V, 50% is 12.2V and 0%[flat] is 11.9V. Alternatively, just check the battery voltage with a voltmeter across the battery terminals every now and then. Either of these techniques will at least indicate what the degree of 'voltage loss' is. And then all that work won't necessarily show you what's going on! It's easier if one circuit is causing the drop; the recommended technique is to measure voltage across the fuses. The voltages should all be zero as the circuits should be 'dead' but a fuse with a small millivolt drop indicates a 'live' circuit. [But this won't normally spot the device that comes on and goes off again later]. Finally if/when replacing your battery make sure you get a battery with an appropriately high CCA [cold crank amps]. This needs to be higher for diesel engines as they turn over less easily; the A8 diesels should have at least 850A CCA. Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! Last edited by JulianHicks; 29th November 2016 at 06:28 PM. Reason: typos |
Ignoring the first 30 secs, I believe they flash every few seconds [2 -3 in my case]. Not sure if they flash less often before being turned off ... Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
Julian, that's some priceless information. Thanks!
![]() And different AUX heaters are installed on petrol and diesel cars ![]() Guess you have a petrol A8 Lee; these have heaters that can preheat. Diesels have a simpler one that only heats the circulating water in winter. Julian
4.2 tdi Julian , with timer mode enabled in mmi and extra electric water pump fitted , I did it first job on the car when I got it .
One of best mods on the car , I set it in the morn for 30 min run , it's fully defrosted and toasty warm inside , the diverter valve is just not needed . |
Hi,
Thanks for all the advice so far and sorry for the late reply...been a crazy 2 weeks leading up to Xmas at work. Good to know i'm not alone in this. I used OBDEleven for my last scan and have since fired up an old PC with VCDS to do a new scan. I thought i'd follow the advice and start with getting a new battery. I've had the car 3 years and thought it would be good to eliminate that as a factor first. This was my old battery [part number 4E0 915 105 A]: ![]() I bought an OEM battery from TPS for £150 [part number 4E0 915 105 DL]: ![]() I used this video to code the battery in VCDS: https://www.youtube.com/watch?v=IJAScg6JrYI And it was accepted first go: ![]() Quote:
I will post another VCDS scan tomorrow and will keep you posted on progress. I'm off to Holland next week for Xmas so would love to have this sorted. Oli
![]() CURRENT: 2006 Audi A8 D3 4.2 Tdi QS - CLICK HERE FOR PROJECT THREAD: Audi Exclusive Azure Blue, Amaretto brown interior, facelift rear lights, S8 mirrors, B&O, ACC, Digital TV, glass sunroof, Fridge, Extended Leather Pack 2, wooden steering wheel & gearknob, keyless entry, keyless start, electric boot, softclose doors SOLD : 2000 FL Silver D2 4.2 QS - Solar sunroof, Bose, Blinds, NavPlus, Playstation, DVD, wireless headphones, iPhone AV connection, RS6 steering wheel, chrome mirrors, phone prep, xenons, servotronic steering, Rear screen, TV-in-motion, NavPlus Alu rings, S8 exhaust, S8 bonnet grille, 385mm D3 S8 brakes, rubber winter mats, De-badged rear, US rear indicator clusters, 20" Final Edition diamond cut wheels, 15mm Eibach Pro spacers (front), 20mm H&R hubcentric spacers (rear). Audi A8/S8 D2 Flickr Group Last edited by Oli18; 17th December 2016 at 05:39 PM. |
Here is a fresh scan using VCDS below.
I got in the car after i drove it 3 hours earlier. I thought i'd check the battery regulator and went into the 'advanced measuring blocks' and it showed 12.2V...and this dropped to 11.95V over 20 mins of scanning. Is this normal? ![]() Thanks, Oli Saturday,17,December,2016,20:13:54:17815 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 16.8.4.2 Data version: 20161129 DS267.0 www.Ross-Tech.com VIN: WAUZZZ4E26N019357 License Plate: OVB2 Mileage: 206770km-128483miV3 Repair Order: Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0E 11 31 13 15 16 17 18 19 1D 1E 25 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 72 76 77 VIN: WAUZZZ4E26N019357 Mileage: 206770km-128480miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: Not registered 0001 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Cannot be reached 1100 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI A000AGMª0070 Revision: --H01--- Serial number: AUX3Z0F0383869 Coding: 0011773 Shop #: WSC 00759 210 86480 VCID: 2241C55DFD8A6652FF-8076 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 P HW: 09E 927 156 B Component: AG6 09E 4,2lTDI RdW 0030 Revision: --H01--- Serial number: 0076831 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 30653F15A366C4C279-8064 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0008557 Shop #: WSC 02313 000 00000 VCID: 2241C55DFD8A6652FF-8076 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0F0383869 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58B5A7B5EB56FC82D1-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 1 Fault Found: 00179 - Access/Start Authorization Antenna; Drivers Side (R134) 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 4 Fault Frequency: 0 Reset counter: 103 Mileage: 206768 km Time Indication: 0 Date: 2016.12.17 Time: 19:56:22 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 02313 785 00200 VCID: 244DC345E79E68628D-8070 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300AC067562505 Coding: 0000002 Shop #: WSC 12345 111 45725 VCID: 3A711D3D751A0E92C7-806E Subsystem 1 - Part No: 4E0 910 609 A Component: Bedienteil MMI H42 0020 Subsystem 2 - Serial number: 318HI037505510 Subsystem 3 - Serial number: 7429.08.030000000000010000ÿ Subsystem 4 - Serial number: 010000ÿ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 D Component: KLIMAAUTOMAT 016 0400 Revision: 00000030 Serial number: 00000000088042 Coding: 0022563 Shop #: WSC 02311 785 00200 VCID: 1C3DFBA5DFEE50A235-8048 1 Fault Found: 01592 - Air Quality Sensor (G238) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 103 Mileage: 206778 km Time Indication: 0 Date: 2016.12.17 Time: 20:07:19 Freeze Frame: Temperature: 30.0°C ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q Component: ILM Fahrer H14 0230 Coding: 0133122 Shop #: WSC 02313 785 00200 VCID: 3669090D4102EAF223-8062 Subsystem 1 - Part No: 4E2 910 113 B Component: Wischer WWS D3 H50 0420 Coding: 00000036 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH11 0050 Coding: 00139548 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBF8049216 Shop #: WSC 00000 000 00000 VCID: 1C3DFBA5DFEE50A235-8048 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI A000AGSª0070 Revision: --H01--- Serial number: AUX3Z0F0383869 Coding: 0011773 Shop #: WSC 00759 210 86480 VCID: 2241C55DFD8A6652FF-8076 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Labels: None Part No SW: 4E0 910 561 F HW: 4E0 907 561 F Component: ABSTANDSREGELUNGH03 0020 Coding: 0011154 Shop #: WSC 02313 785 00200 VCID: 254BDE41ECA4916A9A-8070 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H12 3610 Revision: 91H12360 Serial number: 0037P000DLH0 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 2757D44996A8837AA8-8072 Subsystem 1 - Serial number: 63328RB400E24D6EV Subsystem 2 - Serial number: 63428RB400E2571CK Subsystem 3 - Serial number: 63528RB400E2571DM Subsystem 4 - Serial number: 63628RB400E256F4R Subsystem 5 - Serial number: 63729RB400D364F8W Subsystem 6 - Serial number: 63829RB400D364A8S No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112151 Shop #: WSC 02311 785 00200 VCID: 65CB9E41AC24516A5A-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 980 N HW: 4E0 920 980 N Component: KOMBIINSTR. VDO H70 0410 Revision: D02 Serial number: AUDID3F0000091 Coding: 0000403 Shop #: WSC 31177 001 1048576 VCID: 3261351DAD6AF6D20F-8066 1 Fault Found: 16346 - Control Module - ROM Error 014 - Defective Freeze Frame: Fault Status: 00000011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 60685 km Time Indication: 0 Date: 2008.10.08 Time: 08:32:47 ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 A HW: 4E0 815 069 F Component: Heizgeraet H07 0110 Revision: 0000000C Serial number: 00000009006406 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 1A31FDBDD5DA2E9227-804E 2 Faults Found: 01412 - Glow-Plug with Flame Monitoring (Q8) 008 - Implausible Signal 02251 - Heater Unit Locked 000 - - ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.clb Part No SW: 4E0 910 468 B HW: 4E0 907 468 F Component: Gateway H11 0090 Revision: 11 Serial number: 19004061088029 Coding: FEFFFBDF2B7504 Shop #: WSC 11111 123 12345 VCID: 2757D44996A8837AA8-8072 2 Faults Found: 01325 - Control Module for Tire Pressure Monitoring (J502) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 103 Mileage: 206778 km Time Indication: 0 Date: 2016.12.17 Time: 19:55:21 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 103 Mileage: 206778 km Time Indication: 0 Date: 2016.12.17 Time: 19:55:21 ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl Part No SW: 4E0 910 218 HW: 4E2 905 218 Component: FPI_1 H06 0060 Revision: 06000106 Serial number: 11082004063652 Shop #: WSC 00048 210 176595 VCID: 5EB9B1AD897202B29B-800A No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H20 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 00000 000 00000 VCID: 2B5F28794A40A71A4C-807E No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0F0383869 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58B5A7B5EB56FC82D1-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 1 Fault Found: 00179 - Access/Start Authorization Antenna; Drivers Side (R134) 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 4 Fault Frequency: 0 Reset counter: 103 Mileage: 206768 km Time Indication: 0 Date: 2016.12.17 Time: 19:56:22 ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 J HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 6310 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2A512D7D85BABE12B7-807E No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063342 Shop #: WSC 02313 785 00200 VCID: 244DC345E79E68628D-8070 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 D Component: MNS ECE H47 1060 Revision: 00000000 Serial number: 364AS067525548 Shop #: WSC 02313 785 00200 VCID: 3B7F18397A20379ADC-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H03 0090 Serial number: 00000534600055 Coding: 0036036 Shop #: WSC 02313 785 00200 VCID: 1D3BF6A1C4F459AAC2-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 B Component: Türsteuer.FS BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 2045CF55F3867442E9-8074 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 B HW: 4E0 907 289 Component: Komfortgeraet H05 0010 Revision: 00100005 Serial number: W040601170155 Coding: 0004349 Shop #: WSC 02313 785 00200 VCID: 2855D7759BB68C02A1-807C Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P14H06 0070 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H04 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: None Part No SW: 4E0 910 466 D HW: 4E0 035 466 Component: BO_D3 H06 0320 Revision: 11S00002 Serial number: 00504060002262 Coding: 0000023 Shop #: WSC 00759 210 86480 VCID: 2757D44996A8837AA8-8072 Subsystem 1 - Part No: 4E0 910 465 B Component: BO_D3_SLAVE H31 0310 Subsystem 2 - Serial number: 01901060000773 Subsystem 3 - Serial number: 0219.01.060000000100030013ÿ Subsystem 4 - Serial number: 030013ÿ No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000078312 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E39F1ADC9F242B2DB-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 B Component: Türsteuer.BF BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 2045CF55F3867442E9-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0001031 Shop #: WSC 00011 888 96745 VCID: 1F47CCA9CEF84BBAD0-804A No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 F Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000006 Shop #: WSC 02313 785 00200 VCID: 3D7B1621643439AAE2-8068 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 L Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 304AS067613997 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 31633A11A86CCDCA76-8064 No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 A HW: 4E0 919 148 Component: R0078 TVhybridTuner 0280 Revision: R0H05000 Serial number: 76300700425102 Coding: 0000003 Shop #: WSC 02313 785 00200 VCID: 2143CA51F88C7D4AE6-8074 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000010029 Shop #: WSC 00759 210 61239 VCID: 2045CF55F3867442E9-8074 Subsystem 1 - Part No: 000 915 105 DL Component: von VA0 360701103L Coding: 303030393135313035444C5641303336303730313130334C Shop #: WSC 12345 128 00289 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Türsteuer.HL BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 1E39F1ADC9F242B2DB-804A No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Cannot be reached ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000601130467 Shop #: WSC 12336 024 394758 VCID: 3669090D4102EAF223-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Türsteuer.HR BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 1E39F1ADC9F242B2DB-804A No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0030 Revision: 00H12000 Serial number: 08720602003606 Coding: 0301008 Shop #: WSC 02313 785 00200 VCID: 234FC059E2906F5AF4-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 M HW: 4E0 862 335 Component: Handyvorb2 H13 1130 Revision: 00000000 Serial number: 00000007608675 Coding: 0010900 Shop #: WSC 00000 000 00000 VCID: 2C5D2B658F4EA02245-8078 No fault code found. End-------------------------(Elapsed Time: 04:17)--------------------------
It depends on load, as you were doing VCDS scan I assume you had ignition on and a few consumers like fan etc so voltage should be OK. Without load you should see about 12.6V on the fully charged battery but with a load it will drop depending on load. When you have glow plugs on and starter running it could even drop below 9V but with light load it should not drop muchbelow 12V
