![]() A few questions - Am i right to assume that i don't have to change out anything on my abs sensors? - It looks as though the red-stuff pad sensors ahave a different clip [not sure though]. Am i wrong or should i be prepared to have to make mods? - I'm thinking of upgrading the brake fluid to MOTUL RBF 600 - i would consider others but have read good things about it especially for track days. Thanks in advance. Oli ![]() Oval shaped pad sensor clips: ![]() ![]() Current pad sensor clips: (image from audipages)
![]() CURRENT: 2006 Audi A8 D3 4.2 Tdi QS - CLICK HERE FOR PROJECT THREAD: Audi Exclusive Azure Blue, Amaretto brown interior, facelift rear lights, S8 mirrors, B&O, ACC, Digital TV, glass sunroof, Fridge, Extended Leather Pack 2, wooden steering wheel & gearknob, keyless entry, keyless start, electric boot, softclose doors SOLD : 2000 FL Silver D2 4.2 QS - Solar sunroof, Bose, Blinds, NavPlus, Playstation, DVD, wireless headphones, iPhone AV connection, RS6 steering wheel, chrome mirrors, phone prep, xenons, servotronic steering, Rear screen, TV-in-motion, NavPlus Alu rings, S8 exhaust, S8 bonnet grille, 385mm D3 S8 brakes, rubber winter mats, De-badged rear, US rear indicator clusters, 20" Final Edition diamond cut wheels, 15mm Eibach Pro spacers (front), 20mm H&R hubcentric spacers (rear). Audi A8/S8 D2 Flickr Group Last edited by Oli18; 5th May 2010 at 08:09 PM. |
bump - anyone?
Not sure about the ABS sensors.. I'd suck it and see, but it should be fine as the hub is the same and it has the reluctor ring in it.
WRT the pad wear sensors.. You're probably going to have to chop it. I'd see abotu getting the correct conenctor for the car end and splicing that in to save hassle later. Or.. You could sell them on to a D3 owner at a knockdown price (hint, hint ![]()
No need to change anything on the ABS sensors. The fit the hub carrier and read from the hub.
I did away with the pad sensors because I have a conscientious preventive maintenance process and know exactly how much pad wear I have! ![]() Upgrading to DOT 5 or above depends on how serious a kicking your gonna give the brakes. can't do any harm! ![]()
Thanks guys - really helpful.
Can i just cut off the sensor cables or would i be suffering from a DIS pad sensor fault displayed? Thanks again for your help...next weekend looks good for fitting them now - whoohoo! Oli
Yes, you can cut the sensor cables and join them up so that the circuit is 'shorted' to avoid a permanent pad wear DIS warning.
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten ![]() |
Hi,
So i had a go at this after work and i got to put the old and the new side by side for a moment - i was feeling pretty confident especially after seeing a post here of it just being a straight forward swap of parts...but he does appear to have different brakes to me... ![]() ![]() Then as i tried to mount the first disc and caliper, i came to realise that the calipers actually seem to mount differently - please see the mounting points on the standard A8 caliper vs the new one...they mount on different sides of the bracket (if that makes sense) and no matter what i tried, it just didn't seem to be a standard bolt-on job. ![]() I'm at a bit of a loss now...am i just not doing this right or is this setup just not as straight forward as i had hoped? If the latter, can i fix it somehow with brackets?! I was really hoping to get it done tonight and to test these uber brakes ![]() Your advice much appreciated... Oli
Hi Oli,
I'm not the expert in these areas, but, I believe the pre facelift and post facelift brakes mount differently, and your new brakes came from a D3, so not sure how the heck that fits in to the equation. Anyway, the point is that I think Frank (from memory) is one of the very early facelifts that still have the older pre-facelift front hubs (steel) and thus may have different brakes too. Sorry to be vague, not my area but I know David has muttered these things before.... The facelift D2 S8 is different again as it has brembos which mount differently... It doesnt answer the question, but maybe seeing what D2 (if any?) it was supposed to bolt straight onto might help narrow down the chances of getting it to fit? If its a pre/post facelift problem, and it looks like its a showstopper, and it looks like it might fit mine, I'll gladly relieve you of them as I'm about to spend way more than that on some other brakes, so I could then justify this purchase as a cost saving excercise.... ![]() ![]() Hope you get em to work though..... ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Is the distance between bolt holes the same? The caliper should fit behind the Hub mounting points as the hub has the thread that the bolts fit. If the caliper is to far towards the outside of the car and doesn't centre on the disk you can use shims to move it inward.
If its to far in then you will need a bracket to off set the mounting point. Unless it is only a millimetre or so then you could machine the calliper mounting points.
Oli - PM sent that may be helpful
