Good question ........When the valves are closed or semi closed in some cases the o rings start to disintegrate and the shuttle valves cannot get to the open position , they get jammed up in there bores , they only have quite a light spring that returns them to the open position .
I have only had the 8 for a few years but I am still learning.
Thanks Snap for the enlightenment about heating the car without ignition. Decided to get out of my pit early today and try it, magic. I can now warm the car up without the expense and work needed to fit the extra gubbins neededto modify the Webasto. On the coaches I drive there is a button that when pressed the Webasto fires up and warms the whole vehicle up to a decent temperature. It's good enough to defrost al the windows and when waiting for hours it keeps me warm and toasty without running the engine.
Now that I've had my porridge and a cuppa the grey cells have started to work a little.
The ON/OFF button in the climate control must have a pair of contacts that are closed when the button is pressed. Is there a way to locate these contacts and connect a set of relay contacts across them? I'm thinking that if this is possible a remote could be added to switch the Webasto on from indoors. I have a remote TX/RX pair that has a relay built into the receiver that could do this. Something like £5 from the Chinese gang.
Spot on Neil, but for practical use next best thing to useless.
Bit unusual for the Germans but not been followed through. It is a one shot setup, you can only select one of the timers at a time and as they are date as well as time sensitive you need to set it up for each and every time you need it. No good if you park up in reasonable weather and overnight the temperature plummets. When you fit V55 and the extra bits to the Webasto it is also a good time to wire in a remote so that when you look out of the bedroom window and see an all white car you just click your remote and the car warms up. I'm just thinking about a cheap and easy way to save me tramping out to the 8 in my dressing gown, the neighbours rottweiller is frightened enough already. One day I'll tell you the tale of when I invented hazard vwarning lights and the Deutsche Polizei borrowed the idea.
The timers don't seem to work, they fire up the webasto, but the water is not pumped by V50 as it is not activated and so it soon gets up to temp and goes to minimum output.
There is a vacant socket with a blanking plug on the webasto for a V55 pump which is not fitted as standard and is hard to retrofit. Manually turning the climate on does start the V50 pump. It's ashame it works this way and would be inetrested if others find the same. |
I tried your way this morning Snap and it seemed to work.
Now waiting for an all white morning to put it to the test. Will let you know. In the meantime I'm trying to work out where I can fix my remote receiver.
Am guessing this Webasto thinggy was an add on or a TDI thing ???
And I don't have it on my 4.2 V8 ???
Current : 2005 A8 Sport 4.2 V8 D3 - LPG working! Previous : 1998 S8 PF 4.2 V8 D2 - Gearbox died ~120k 2002 S8 FL 4.2 40v V8 D2 Prins LPG - Engine valves met pistons ~230K Also : 1996 Jeep Grand Cherokee 4.0l (Post Apocalyptic makeover) 2003 Brabus Smart FourTwo (should sell) 2003 Mazda Rx8 2.3 (might sell) |
