In terms of draining the reservoir, the length of the pipe doesn't matter - you've got the same volume of fluid going through it whether its an inch long or ten feet
![]() The shortest first logic to bleed the system makes sense because any air from the master cylinder or ABS module will come out sooner. Elsawin does give the two specific procedures though - with and without ESP. Personally I think it makes no difference either way for a fluid change ![]() |
Great. I shall delve into that as well for instructions.
Hi Sean, there's something in the back of my mind regarding performing output tests on the D3's ABS module that it logs an error that can't be erased. I remember Snapdragon posting something about it.
Here is what I have on the ESP procedure.
MJ is correct of course, as always ![]()
Johannes _________ Audi S8 -99, Pearlescent, Alcantara/silk napa leather, Burr walnut insert, Alcantara roof lining upper pack A8 32V engine ----- Jeep Grand Cherokee -98 |
Ignore my comment, just now realised it's your D2.
