As this is a Mackie's gearbox, I'm not touching it
![]() Both CV boots needed replacing Clips removed Cut the boot in half and remove it A sharp whack to the centre of the joint with a chisel and lump hammer will pop it off the circlip Slide the joint off the splines The circlip is on the left. The plastic bushing and cup-spring on the right hold the joint tightly on the splines. These all get replaced With the hardware removed, I put a plastic bag over the splines so the boot slides on without getting caught on any sharp edges New circlip, bush and cup-spring Rotate the shaft to vertical for the next bit New grease The joint is just sitting on the end of the spline now Put a spare bolt in the end of it to use as a drift Another sharp whack with the lump hammer knocks it over the circlip and it's locked in position again The new boot is held in place with the proper crimp clips. Any mechanic who uses cable ties on CV boots should have his tools confiscated ![]() This is the proper tool for crimping the clips On to the other side. Not only was this boot held on with a cable tie, but whichever donkey had messed with it had beaten on the outer joint with a hammer and not bothered to to replace the bushing or cup spring so the joint was loose on the spline ![]() ![]() |
