Old 11th April 2019, 08:26 PM
Great work!
Seems a bit drastic for a single broken vent slat!
It was a little more than that Stephen had commented that occasionally the shifter would get stuck, and on investigation I discovered a fault code in the TCU for the V110 shifter interlock solenoid. Since I had a spare shifter I swapped it over. V110 is the silver cylinder on the bottom left of the shifter here.
Old shifter removed - this is how much stuff you have to remove to get to it
Replacement fitted
I forgot to take any more pics of putting the rest of the interior in. Stephen's and Jim's had to play bunk beds for a night until Stephen's went home! Since Stephen's had just had all its leaks fixed, it got top bunk
Who's sleeping in my bed?
The last step - a new relay box cover made from marine ply. I wanted to infuse this with polyester resin to make it completely waterproof but I ran out of time. I'll do that next time.
A brace of beautiful black Final Editions basking in the sunshine Stephen's waiting to be picked up, Jim's waiting to come in.
ID:	21361   Click image for larger version
ID:	21362   Click image for larger version
ID:	21363   Click image for larger version
ID:	21364   Click image for larger version
ID:	21365   Click image for larger version
ID:	21366   Click image for larger version
ID:	21367   Click image for larger version
ID:	21368   Click image for larger version
ID:	21369   Click image for larger version
ID:	21371   Click image for larger version
Old 11th April 2019, 08:36 PM
I’m going to suggest a new trophy fr the Annual Meet - for the person who posts a D2 question that MJ doesn’t answer in almost no time at all! Apart from this amazing lady’s knowledge and mechanical expertise (should that be ‘genius’?), her commitment to this forum is outstanding! Just need to find out her favourite tipple to take when I pick the car up. I’m running out of superlatives!
Old 11th April 2019, 11:38 PM
27litres's Avatar
27litres 27litres is offline
Thanks MJ!
You're a champ!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 12th April 2019, 10:03 PM
One word describes MJ . . . Magic
Old 13th April 2019, 11:21 AM
More like MaJic.
Old 17th April 2019, 04:32 PM
So Stephen, whilst your car was a notable winner of several accolades, underneath it all it was a right mess....
After saying that I'm now afraid of arranging an appointment with Dr D2 in case mine turns out worse
It was - but nothing too serious or terminal, though that might not have been the case had the chain pad not managed to hang on till the bitter end: Herman's had very little TLC over the last three years, and I could tell on the drive down that he was well overdue the sort of care that Michaela provides.
Underneath it all however, he was basically in very good nick - as MJ's comments about the engine condition show - but just needed a good thorough service and lots of little(ish...) jobs done. Oh, and the Milltek fitted .
It is extraordinary how much better the car now feels and drives - almost as responsive as my Tesla now, which is saying something. And well worth booking an appointment with the doctor, David. You know you want to.
Old 6th March 2022, 10:51 AM
Next job - find out why the ECU won't communicate with VCDS. No continuity between the body harness and ecu connector...
I am having the said same issue with my VCDS Lite. Actually with my cheapo reader as well. The cheapo says linking error, VCDS unable to connect. Did you go direct to the ECU or are there prior items to check? I have checked the terminals at the OBD2 port and all seems good, used a breakout box and the resistance between terminals also seems to check out.
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 6th March 2022, 07:07 PM
I checked continuity between the OBDII port and the ecu box connector, which was fine, and then from the ecu box connector to the ecu itself, which wasn't.
Do you have wiring diagrams? I know the diag pin on the ecu is #43 but I can't remember which plug it's on in the ecu box.
Old 6th March 2022, 09:45 PM
Thanks MJ.
I think I have diagrams, just need a quick refresh. Will go digging next week.
Paul
Gosport UK
Honda Jazz
Old 7th March 2022, 11:07 AM
sarg sarg is offline
This seems similar to sticky selector I sometimes get, doesn't want to move easily out of Park
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
