#101
That's kind of on the borders of some nice bits of Bristol, and there's a lot of similar old school sites like that around that area due to the victorian explosion in building in that area. I guess chosen for the proximity to where the PO lived than any basic capability? From memory he was in Redland/Whiteladies Road area?
If the PO saw that bodgery I suspect he'd be equally pee'd off that he'd spent good money on work that was done to such a poor standard. For most folks if you can't see it, you'd have no way of knowing.....
#102
Got to be a tight squeeze to get an A8 in there.
4.9 star rating on Google from 16 reviews!
#103
Cars... '93 Audi Coupe 2.0 Alpine White (sold) '99 Audi S4 Merlin Purple - K04 upgrade to 412hp (sold) '00 Audi S8 Agate Grey (Sold ![]() '11 Audi Q7 4.2tdi Unknown Red (Classic Red Pearl Effect - thanks MJ) |
#104
I've had to sack 'engineers' over the years for repairing machines in a similar manner - best one was an "engineer" doing an engine rebuild on a Nissan 2.3 diesel engine (aluminum head). He was standing in the engine bay 'torqueing' down the head with a 1/2" drive impact gun......left my employment about 2 hours later
Daily drive: 2016 Infiniti QX70.....a car that's even more complicated than my last Infiniti FX to modify ![]() Current 'Project': VW Crafter CR50 4 berth camper van Previous 'Projects': 2006 Subaru Legacy Spec 'B' 3.0R, 1994 Ex-MOD Land Rover Defender, now "civilianised". 2000 Audi S8 FL www.whall.co.uk |
#105
Got the engine and gearbox split and the engine mounted on the stand. Grot everywhere.
Bugger ![]() If it can't be repaired then I will get another engine out of stock and put that in instead, but I'm carrying on cleaning it up at the moment I think, if it does go back in, its going to need a bit of an Italian tune-up to clear the pipes a bit ![]() |
#106
that is ridiculous! I thought my 2,8QS was bodged because parking sensor connector was held with a zip tie, this is something else!
#107
Lets call him 'Mr Anti-Midas' and assume he's been everywhere and touched everything. At this point I see his work, sigh, and carry on. I'm going to point out just two more of his little touches, and then stop so the thread gets a bit more positive
![]() I continued stripping and cleaning the engine tonight. I took the unusual step of removing the injector rail on this one because all the inlet manifold bolts are rusty and full of crud, and the injector rail is in the way of getting a tool straight on to them. These are too bad to risk a slightly off-square allen key, plus the manifold needs sandblasting and repainting anyway. The vacuum manifold system was disconnected when the actuator pods broke rather than fixing it Lots of schmutz round the base of the manifold, and this is after cleaning! a little grubby inside, but I can clean this when it comes apart I turned the engine over and took the inlet manifold off with it upside down to make sure none of this grit and tar fell in to the inlet ports I cleaned it upside down too, lying on the floor. You have to pay extra for this ![]() Final Mr Anti-Midas touch - the guide pins always break when the manifold comes off, so he drilled them and held them back in place with small nails. Inventive, but sadly pointless as they are readily available and very cheap ![]() Usual muck in the valley. I forgot to get an after pic, but its all nice and clean now Condensation aside, the engine is remarkably clean inside for a quarter of a million miles, and the chain tensioners are barely worn. This engine was fitted when the car was on 200K and the engine was about 127K. The car now has 320K making the engine 247K ish. For most of 2020 the car lived in the workshop, and had to be moved in and out frequently, doing about 50 yard journeys. As a consequence, the engine is full of condensation and the oil is quite brown, but this will all evaporate when it gets running again and has an Italian tune-up. The colour inside and total lack of sludge indicates that at least it has had regular good-quality oil changes, and has done lots of nice long journeys. It wipes clean and is in excellent condition under the coating of light mayo ![]() Ew! Normally this would be indicative of very bad things, but I know exactly why it like this so I'm not concerned ![]() Also this evening Mike and I contrived a plan to repair the broken engine mount boss, without welding it. My tig guy is a trained and coded welder and even he isn't sure what would happen welding the hypereutectic Alusil engine block, so we're not going to. Since the engine hasn't fallen out in the last 120K miles, the remaining two bolts can apparently take the dynamic loads generated in this area so rather than risk damaging an otherwise good engine by welding it we have a mechanical solution instead. Its going to involve some custom tooling, and a custom repair piece to re-form the thread. More on that as it develops ![]() |
#108
Now, that doesn't happen very often with me - the first one today was Apricity (to describe today's lovely weather in Manchester..), which I though was quite a good one - but Hypereutectic is even an even better one! Day off tomorrow now
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ![]() ![]() (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ![]() (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. |
#109
Home come the inlet manifold of V8's is metal, and plastic on 2,8?
#110
Cost I would expect. The V6 went in cheaper models and so given the larger volumes it would have been cost effective to tool up for injection moulding, plus the port length changeover is a much simpler mechanism. That might not have been practical in plastic for the V8.
