Hi guys
Hope everyone is well Great forum for info This is my second chance if owning an A8D2 I had brief spell with a 2.8 but have now found a low owner D2 3.7 FL It is an aqua blue d2 facelift paint code ly5x I’m hoping I could get some help on some issues with the car. I have notice some have resolved the more I’ve used the car The car has sat for 6 years but the old man use to transport every year to get it MOTd and would rectify each advisory 1. Looking for auto dimming left mirror lens - but feel I will just have to buy the standard ones 2. Parking sensor light flashes with a long beep - possible dirt as hit a gravel truck on my way home and not had a chance to clean the car - will possibly need diagnostic to see which sensor? 3. Looking for the gloss triangle trims on the rear passenger doors - does anyone know the part number?? 4. Sunroof doesn’t open when control fully turned open- need to turn it half first then full to make it open - tilt function works fine 5. Washer fluid warning constantly on?any fixed or any advice what the part number is for the sensor? 6. Cruise control not coming on - have read need to keep switching it on and off due to connectors I have currently managed to source floor mats I have fixed the water jets - one loose and one clogged up Now it just needs a deep detail with all the moss on it Will post pictures of progress The blue one is my current daily The R32 is my baby in the garage The silver D2 is my old 2.8 PF Thanks Dan |
Welcome.
Where do you live? 1. I will have 2 available by the end of next week. 2. Use VCDS, you will know it seconds. Forum sponsors probably have a good used one. Chinese sensors work ok for the rear sensors, for front ones only fit geniuine, i had to learn this the hard way. 3. What steamship said. 4. I would start with inspecting the switch. 5. Is the liquid actually there and washers working? 6. I would start with a VCDS scan. Parts catalog is here: https://www.lllparts.co.uk/catalogs/ Last edited by Ronin; 30th January 2023 at 03:21 PM. |
Left outer 'corner trim' - Black - 4D0853273B 5PV Right outer 'corner trim' - Brilliant black - 4D0853274 Y9B Right outer 'corner trim' - Black - 4D0853274B 5PV You have to dismantle the door and remove the top section to get access to it. For those who have done it, they usually just sanded down the original and repainted. Check out the following PDF located in the D2 Common Faults > D2 Tech Dump thread (lots of excellent PDFs), starting at page 81: Service Manual General Body Assembly Exterior (Rep groups 50 55 57 58 60 63 64 66).pdf If attempting this yourself, when removing the door card, there is a very small clip securing the bowden cable to the interior door handle. Try not to lose it (MikkiJayne has 3D printed replacements). The top section of door is held on by four bolts. Mark their position before removing for later when refitting. There is also a metal shim, which again you should mark the position of. Quote:
While you're here, pop along to the Introductions page and introduce yourself. It's also worth going into your User CP (at the top left of every page) and add some details like your location (handy to have if looking for help in your area) and also a signature, where you can add details like spec of car (ideal when posting a question, as then we don't have to ask about the spec of your car).
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! ![]() My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds Last edited by steamship; 30th January 2023 at 03:43 PM. Reason: Link to PDF |
Guys thanks for the reply Would be interested in the mirror lens I am based in Leicester Will try update my profile Thanks again Will give the sensors a clean and if no luck will need diagnostic Hopefully the more I get to use the sunroof the better it will be at opening but not had a chance with the cold weather and work The reservoir is full so I guess it must be the sensor - anyway if cleaning the sensor?any instructions how to remove the reservoir or sensor? Thanks again in advance |
Washer fluid warning will be the pump - the sensor is built in to it. Often when they sit for a long time algae grows in the tank and then blocks the pump / sensor. Its under the right hand headlight, but best to take the tank out and clean it thoroughly with bleach / mould remover. Wear breathing protection / face mask as the tanks can grow legionella bacteria and you don't want to breath that in. Front right arch liner, right headlight, and air filter box out, 3x M6 bolts + 2 hoses and it tilts backwards out of the wheel well. Its usually worth buying new grommets for the washer pump as the old ones don't reseal after replacing the pump.
Another thread worth reading is the following one on the various drainage points around the car. This is especially relevant if the car has been left for six years, and doubly so if left outside:
http://forum.a8parts.co.uk/showthread.php?t=16008
As you say, hopefully just a bit of corrosion built up on the switch contacts over the years of not being used. Just go for a drive and keep flicking through the various cruise control switches. Hopefully after a few dozen cycles they'll work.
Using VCDS you can check whether the cruise control switches are operating, if corroded the signal can be intermittent or need firmer/repetitive pressure.
Some people have also recommended squirting contact cleaner into the stalk and then exercising all the switches vigorously. Mine didn't work at all when I got the car, but repeated "exercise" has made them fairly reliable. PS Which area of Leicester? I'm from there originally and still have relatives in various districts.
Cheers John G
2010 B8 S5 Sportback quattro 3.0 Supercharged in Sprint Blue (current girlfriend) 2000 D2 A8L quattro 4.2 in Audi silver (my ex-girlfriend) |
I’m from Oadby
Thanks for the tips will keep applying the buttons
2002 Audi A8 D2 3.7 Quattro AquaBlue |
