Go Back   A8 Parts Forum > A8 D4 > D4 - Body and Exterior
D4 - Body and Exterior Bumpers, bonnets, glass, trims - Everything outside
Old 26th May 2024, 07:24 PM
Horrgakx Horrgakx is offline
Default Ea\se of fitting badge on front grille
I think the car was delivered without the W12 badges, but I want to put them back on.
The stick-on ones are fine, but what about the badge in the front grille - how easy its that to fit? (worth considering glue??? )
[EDIT] sorry for the typo mistake in the subject line, the silly forum won't let me edit it.
A8L W12 (D4 2015)
Old 27th May 2024, 07:27 AM
Parts wise, both should still be available from Audi themselves. The badge itself is part number 4H0853736A, but you also need two small clips, part number 8L0807180.
Check out the following PDF from page 336 on fitting the front badge, and page 334 for the locations of the side and rear badges:
https://forum.a8parts.co.uk/attachme...8&d=1430167240
Old 27th May 2024, 07:32 AM
That's fantastic thankyou very much!! Looks like an easy job then. I had imagined having to disassemble the entire front-end to get at fiddly clips behind there lol.
That PDF is gold too. I was looking for something like that, I found an online version but this is great. I need to change the external heated mirror glass too and just a couple of pages up it's right there!!
Thanks again.
A8L W12 (D4 2015)
Old 27th May 2024, 08:38 AM
It's also worth checking out the following thread which has a lot of associated PDFs for the D4:
https://forum.a8parts.co.uk/showthread.php?t=8379
Old 27th May 2024, 08:39 AM
Ta
A8L W12 (D4 2015)
Old 12th June 2024, 12:47 PM
Has anyone fitted the clips on the front grille? Looking at mine I think it's going to be impossible to get behind there to install the clips...
A8L W12 (D4 2015)
Old 12th June 2024, 02:06 PM
Didn't realise there was a mesh behind the main grille. The instructions don't mention it, but I would think that they could be fitted from the front, so long as you don't drop them.
Old 14th June 2024, 07:39 AM
I'm not so sure, looks like I need to get behind there. I wonder how easy it is to get the grill off....
A8L W12 (D4 2015)
Old 14th June 2024, 09:52 AM
Page 267 of the above mentioned PDF has an exploded diagram of how it was put together and how to remove it. I don't see any mention of the mesh though.
Even by Audi standards, I don't think they require a full disassembly to fit a badge.
Old 29th July 2024, 11:45 AM
Update 29/7/24
I bought the W12 front badge It does look suspiciously easy to fit on page 336 of the Exterior Parts Service Manual but it is impossible to access from the front. As you said Steamship, Page 267 of that manual shows a simplistic exploded diagram of how the grille is attached but I had a lot of head-scratching over the weekend so it's still not fitted yet.
Worth noting is that the badge looks very different to that displayed on page 336 - the one I have has 2 long "legs" which go through the grille, at least an inch long.
It's this item here; https://www.ebay.co.uk/itm/266129152...mis&media=COPY
I'll see what happens over the next few days, if I can I'll take photos. But I'm the worlds most impatient person when it comes to this and I tend to prefer giving the job to a garage
A8L W12 (D4 2015)
