Go Back   A8 Parts Forum > A8 D4 > D4 - Body and Exterior
D4 - Body and Exterior Bumpers, bonnets, glass, trims - Everything outside
Old 14th June 2024, 07:39 AM
Horrgakx Horrgakx is offline
I'm not so sure, looks like I need to get behind there. I wonder how easy it is to get the grill off....
A8L W12 (D4 2015)
Old 14th June 2024, 09:52 AM
Page 267 of the above mentioned PDF has an exploded diagram of how it was put together and how to remove it. I don't see any mention of the mesh though.
Even by Audi standards, I don't think they require a full disassembly to fit a badge.
Old 29th July 2024, 11:45 AM
Update 29/7/24
I bought the W12 front badge It does look suspiciously easy to fit on page 336 of the Exterior Parts Service Manual but it is impossible to access from the front. As you said Steamship, Page 267 of that manual shows a simplistic exploded diagram of how the grille is attached but I had a lot of head-scratching over the weekend so it's still not fitted yet.
Worth noting is that the badge looks very different to that displayed on page 336 - the one I have has 2 long "legs" which go through the grille, at least an inch long.
It's this item here; https://www.ebay.co.uk/itm/266129152...mis&media=COPY
I'll see what happens over the next few days, if I can I'll take photos. But I'm the worlds most impatient person when it comes to this and I tend to prefer giving the job to a garage
A8L W12 (D4 2015)
Old 30th July 2024, 07:27 AM
The part number I bought is 4H0853738T94.
A8L W12 (D4 2015)
Old 30th July 2024, 08:09 AM
That looks like it's designed to just clip in. Is the single shorter protrusion some sort of release latch?
Old 30th July 2024, 11:31 AM
Good question. I'll give it a closer dose of looking at.
A8L W12 (D4 2015)
Old 30th July 2024, 12:20 PM
The manual makes reference to two retaining clips (8L0807180), and that's the awkward part of the exercise.
Name:	Screenshot 2024-07-30 131529.png
Old 30th July 2024, 07:48 PM
I tried a dry-fitting just now prior to going anywhere near it with clips, here's a video of it. I can't get it to settle into where I think it should go.
I'm trying it in this position because if you notice on the grille, the badge has two notches to help it locate, and the vertical black strip on the grille has a small raised notch likely used to locate it vertically. I just can't get it to sit right.
Here's the video; https://youtu.be/4u_mRppsF-I?si=XCl5KtSnvnPvFndy
A8L W12 (D4 2015)
