Old 20th July 2024, 10:41 AM
I'll answer the easy question first. The relay part number is 8A0951253A and is stamped with the number 203. It sits in position 7 in the relay plate in the passenger footwell.
EDIT: Even though I have the full loom for the solar sunroof (I never fitted mine) I wanted to find ITs thread on it, which has a proper explanation of the connectors. If you check the thread, you'll see that there is a single wire that goes to the climate module. The odd thing was IT never showed the second part of the loom that runs to the HVAC unit itself. The only sign of it is in the closeup of the big fuse connector.
https://forum.a8parts.co.uk/showthread.php?t=5370
UPDATE: I also came across the following two lines as to why it may not be working. The first is from ELSA and the second in response to why someone's wasn't working, so not sure about the latter:
if the "residual heat" function is active
middle vents (front and back) are opened
Name:	A8D2 Relay Plate Location 7.jpg
Last edited by steamship; 20th July 2024 at 11:14 AM. Reason: Added link to ITs solar sunroof thread
