Go Back   A8 Parts Forum > A8 D2 > D2 - Common Faults
D2 - Common Faults Quick links to all known common faults and their solutions
Old 24th October 2024, 09:37 AM
donp38 donp38 is offline
Hi All.
I have at least two leaks.
First the boot is getting water in. The spare wheel well is getting water.
second the driver side foot well is getting water. water in right side cubby in dash also.
Any ideas?
Many thanks.
Old 25th October 2024, 09:09 AM
For your first one, I'd check out numbers 5 & 4 in my first post in this thread (#4). More likely to be 4, as 5 would tend to result in a wet battery compartment.
For your second one, I'd check out numbers 1,2 & 3 in the same post mentioned above. If you hear sloshing, I'd suspect number 1. If it was the passenger side, I'd definitely look at number 8. In fact, just deal with number 8 regardless, before it becomes an issue.
Old 25th October 2024, 11:04 AM
IIRC, MJ/Michaela/Micky Jane made a batch of the boot cable grommets on her 3D printer. Might well be worth a PM to see if she has any left.
Old 3rd November 2024, 08:00 PM
Unhappy
Many thanks.
first time today to have a look.
regarding the boot, (we have new MJ gromets fitted) with my son in the boot armed with a torch.
copious water sprayed on the boot, then on the roof etc.
no evidence of water ingress. hmmm any ideas what next?
the front leak is strange, pours in on the drivers side..
cant see the tube by the hinge...
both these leaks are really serous...
Old 4th November 2024, 08:19 AM
Missed this in your previous post. What/where is this 'cubby'?
copious water sprayed on the boot, then on the roof etc. no evidence of water ingress. hmmm any ideas what next?
Is it just the spare wheel well? i.e. are the two spaces where the battery and amplifier go on either side dry? Is it possible that there is a crack/hole in the spare wheel housing? Also, considering it just seems to be glued in place, maybe some of that has deteriorated. Is it time to put your son in the boot again, and then turn the hose straight up at the bottom of the car?
the front leak is strange, pours in on the drivers side.. cant see the tube by the hinge...
I know on mine that the tube on the drivers side is very difficult to see. I'd be tempted to remove the knee panel under the steering wheel, the fuse cover and also unscrew the fuse box assembly, so you can see as much as possible. Then, when it's dark, park the car nose down and to the right, open the sunroof and then put in a small quantity of water with a UV dye in it. After that, it's a case of using a UV torch to check the inside footwell and sides. Either the drain coming down from the sunroof has got damaged, or worse, become detached at the bottom.
Name:	Screenshot 2024-11-04 090634.png
Old 7th November 2024, 10:00 PM
Great idea.
We will get onto it at the weekend.
Many thanks
Old 15th January 2025, 09:00 PM
I am still struggling.
What do people suggest.
Audi Specialist garage or a good body shop
Old 16th January 2025, 09:30 AM
Did you have any joy with my suggestions in post #35 above?
You mention in post #34 that you've fitted the grommets MJ made, which eliminates the main culprit of water ingress into the boot because of how they disintegrate.
The only other possible source of ingress, which is more common on the D3, is from around the rear light clusters.
