#31
I actually filed the remains of the narrow piece of plastic off the clip and the trim and used a piece of plastic as a support along the whole length of the clip to getit to the right height. I think that superglue and a tiny pin may be the answer. Not that I am getting obsessed at all.....
and thanks for keeping the back up trim to hand. ![]()
#32
![]() There really isn't much room down there, and access is tricky without major dismantling which this doesn't justify. ![]() From nowhere a thought entered my brain - magnetic reed switches, typically used on door alarms! These are sealed passive devices, triggered by a magnet moving close to (or away from) the sensor and available in NC or NO varieties. They can also be quite small; I have some in my house that are about an inch long and a few mm wide. It should be easy to fit one onto the pad under the handbrake and stick a suitable magnet onto the handbrake lever. The circuit needs to be open when the handle is down and closed when the lever is pulled up, so an NC type is needed.
#33
A bit of progress at last, proof of concept!
I bought a microswitch from China on eBay that has 3 wires so can be NC or NO. Tested it to see if it works and which wire is which (NO documentation!). It's sort of cylindrical (*2) about an inch long, presumably designed to pop into drilled holes in wooden doors and frames, and works fine. I fished at the car wiring and managed to get some string round it to pull it up, though it's fairly short so won't come up past the handbrake. Luckily it has standard 6.3mm spade (female) connectors so I managed to extend it with some short wires pre-terminated with male spade connectors that I pushed in using a variety of tools to hold, manipulate and push just beyond finger reach. Then I connected the microswitch to the wiring and turned the ignition on. Handbrake warning light appears! ![]() Move the magnet within about 1cm and the light goes out. ![]() Now I just need to work out exactly how to mount it. I think the switch will be bracketed onto the rubber stop below the handbrake and the magnet will go inside the plastic handbrake cover, so that when the handbrake is off it's close to the switch, but when pulled on is lifted away.
#34
Job done, all working fine, handbrake warning light comes on at the first "click" position.
![]() I made a small mounting plate out of thin fairly-rigid plastic - from the lid of a plastic takeaway food carton as it happens. All I did was cut a small rectangle to fit under the handbrake stop (about twice as big) and made two suitably-located and sized holes in it, one for the locating peg of the stop, the other for the reed switch which just feeds in (leads first) from the top behind. The switch just sort of hangs down behind the stop towards the passenger side of the slot; I needed to cut back very slightly (maybe 2mm) a bit of the trim edge under there so that it was snug and vertical. I also rounded off bits of the plate to keep it clear of the handbrake cover. The reed switch needs to be pretty tight up against and behind the stop to be secure and not foul the handbrake or cover. The plastic handbrake cover needed a bit of minor trimming (not visible) as on the inner passenger side there's a vertical return edge about 3" long and 3mm wide that catches/rubs on the plate and reed switch where they can't be trimmed. The magnet slotted vertically into this cover, again after a bit of trimming with a hot knife so that it didn't protrude and jam against the metal handbrake lever. It's just a small magnet inside a lump of plastic so no issues doing that. I fitted the magnet with blu-tak so that it could be moved, but didn't even need to adjust it. I had checked the operating range beforehand so had a good idea where it needed to go. If it's still good after a few journeys I'll reattach it with something a bit more permanent.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 25th October 2014 at 03:47 PM. |
#35
Just to say that after nearly 2 months it's still working perfectly.
#36
Holy thread resurrection!
Today I went to the car just to dig out the locking wheel nut in case it's needed for the failed MOT CV boot repair tomorrow; also started the car to let it run a while. Then I noticed the handbrake warning light, which had been on went off and stayed off. I think my little magnet has finally come adrift after 10 years. Trouble is I can't recall how to easily take all the trim off to refix it again; I think it's just stuck itself to the reed switch! ![]()
#37
Service Manual General Body Assembly Interior (Repair groups 68 69 70 72 74).pdf
#38
Thanks Sean, I'd forgotten about the clamping bolt on the plastic trim - not obvious from the drivers seat.
Job for another day though when the weather is kinder. Edit: That PDF reminded me there was a little captive retaining "plug" under the leather handgrip. ![]() So I just went outside, levered that out with a small screwdriver, slid off the handgrip and lifted off the plastic trim - it didn't need "unclamping". The magnet is still in place (and they don't normally wear out...) and the switch below seems to be in place too. So I can only assume that either the reed switch has failed or some wiring has come loose. Alternatively the lamp in the cluster has failed, though I definitely saw it on earlier today. I'll test it another time and decide what to do. First world problem..... ![]()
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 4th February 2025 at 01:09 PM. |
#39
Talk about going round in circles! Finally fixed this afternoon.
![]() After some rummaging I decided it was probably the reed switch, so I ordered a replacement (you get the magnet too) on eBay - cheap as chips from China and it took less than a week to arrive. But when I bench tested it I realised it was the wrong type, I'd got confused between NC and NO (Normally Closed or Open) not least because the terminology for alarm switches is sort of the reverse of what you might first assume. "Normally" refers to the situation when the control magnet is next to the switch and the commonest type (for doors mainly) is NC. But I needed an NO! Can't send it back to China so it will become a spare for my house alarm. ![]() I then remembered that my original installation used a 3-wire switch that could be set up as either NC or NO so I decided to order one of those - from China again. Again, very cheap. Then today, while waiting for that to arrive, I decided to check on how much slack I had in the wiring and how easy it would be to change either component (switch or magnet). Plenty of slack so I took almost everything out and decided to check it all. Also confirmed the light on the dash was good. The magnet seemed to be OK as it triggered my new (but useless) switch. And the old switch, off the car, also seemed to be ok which puzzled me. ![]() So I went back to the wiring and eventually found a poorly-crimped connector in the extra wiring I added so long ago. Sorted that out and reassembled everything and it's now working fine. ![]() Should have checked it over first rather than assuming where the fault was, though with parts so cheap it sort of made sense to have them anyway. ![]()
