Old 28th April 2009, 08:18 PM
Oli18's Avatar
Oli18 Oli18 is offline
Wow mike...i haven't been on the forum a few days and am in awe with how well you've managed to progress this.
Hats off to you mate.
-Oli
Audi A8/S8 D2 Flickr Group
Old 29th April 2009, 06:06 PM
Today has mostly been a doing and redoing day. I also have a black little finger tip which has caused me no end of problem. This morning it refused to conduct its routine ear wax clear proses, so the right little finger had to do it and then we have union problems with threats of no pickets and demarcation. You don't know how much you use a digit for till you loose it.
There are no piccys today spent most of it fiddling with the suspension to find the best way of installing the control arms. I will do a full how-to when this is all over. Current state of affairs is that I am waiting for seals and o-rings from Audi and will do a start up when they're fitted to the Power Steering Pump and Air Con compressor.
So more tomorrow.
Old 30th April 2009, 07:16 PM
Default Today the Beast Roared
Yep, today after a half day of fitting O-rings to pipes and filling fluid reservoirs and checking everything twice I hit the go key and after 2 long periods of cranking it fired. I was so happy; for 50 seconds then it coughed and I cut the ignition. Vagcom was showing multiple random misfires. Fired it up again and after a few seconds coughed and died. I'm fairly certain it's fuel related.
Anyway. A full Vagcom scan showed no other faults so I think the install has gone well. Will spend tomorrow investigating the fuse and relay for the fuel pump; although I have it very reliable that my pump sounded weird when last heard running! Great a new fuel pump.
Tonight's photo:
Old 30th April 2009, 08:25 PM
entwisi
Guest
Posts: n/a
you do realise that if any of us need an engine swap you know who's door we will be knocking on....
looking good mate! IMHO to have it running in any manner is a superb job. I wouldn't have teh balls to attempt anyting like this so hats off !
Old 30th April 2009, 10:50 PM
Oli18's Avatar
When you leave the Navy, perhaps you should become the servicing arm of A8parts in the south....would get my vote :-)
Old 1st May 2009, 01:39 PM
Default It wasn't the pump! :D
Well I went back in this morning and followed the fault finding process on ElsaWin for the fuel pump to find the pump was working. It just needed fuel!
So a bit of fuel later and..... Some video for you
Tomorrow is bolt it all back together again and go for a test rampage!
Old 1st May 2009, 01:47 PM
DJStrange
Guest
Posts: n/a
Excellent result
Bet you're well chuffed. Sounds nice and ready in the vid.
Conan - Our Hero
Old 1st May 2009, 02:20 PM
A8 Doc A8 Doc is offline
Excellent news!
I was about to say check your fuel pressure, but then carried on reading!
Keep those gas clips nice and tight!
Old 1st May 2009, 04:05 PM
Fantastic Mike...
Great to hear you back in business. And with those new control arms, it should be an awesome ride!
Old 1st May 2009, 04:51 PM
Well done Mike...
I trust it was up to temp before you revved the knackers off it ?
Tags
4.2 v8, engine swap, s8 ahc
