Old 3rd October 2012, 09:34 AM
Which seems to be black/blue on my car. There isn't however any +12V that comes on when the RNS is switched on with the ignition off.
So, short of installing a relay or switch I'll need to have the ignition on to watch TV when parked up.
I also found a description of the multi-pin video connector on a German web site. This might enable the old TV tuner to be dispensed with entirely, feeding the DVB-T directly to the RNS? NF = Niederfrequency = Audiofrequency
(Though the RNS seems to detect the tuner via the 6-pin power lead, unplug that and it's N/A)
- There is no ignition switched power feed to the tuner. Its a constant +12v and the tuner listens to Canbus for signals to turn on and off.
- Directly feeding TV into the Nav unit is a pain as it doesnt take a regular composite feed, its RGB which is what those splitter boxes do - However unless the splitter box generates a canbus signal to say 'im here' then the TV function will remain disabled on the Nav unit. They work well on VW MFD etc as they dont check for this signal. Leaving the tuner in place is always way easier....
