Old 26th September 2012, 09:30 PM
From memory, they are the same wierd connections on the unit behind the seat as the tuner itself.
Its not a massive job to change the loom from old to new. Just back seats parcel shelf and D pillar trims off..... a8parts might be able to sort you a kit.
Car aerials, especially on the move, are nothing like as good as your huge home antenna so you cant afford to have any dodgy wiring or poor connections or you'll likely end up with nothing of much use at the end of it all....
My D3, with factory aerials and factory tuner only gets acceptable reception in city and town centers generally. The rest of the time its next to useless as the audio is forver cutting out. I miss analogue, it was far more useable in a car.
