Old 27th September 2013, 10:02 AM
Just to note that I've plugged in my antenna this morning, it was very easy to do.
I gained access by removing the drivers knee panel, which needs a trim tool, T25 torx and 8mm socket.
1. Prise off the curved plastic trim immediately below the steering cowl, just held by 2 clips.
2. This exposes a couple of screw heads (mine were T25) holding the knee panel, remove these.
3. Remove the 3 screws in recesses in the panel - bottom left and right and in the top right of the storage recess. Mix of T25 and 8mm on my car.
The panel drops down (OBD cable is connected!) and even my big arthritic hands could easily reach the socket on the back of the instruments to plug the receiver lead in.
It looks like this panel has been off before as the screw in the storage recess wasn't actually doing anything - just jammed into a clip that wasn't clipped anywhere and where it should go seemed to have been broken off. Probably removed incompetently before.
So I'm going to have a more careful look and see how it can be fitted better, none of the fixings were actually done up properly.
I'll get the laptop out later and do the coding then "await developments".
