Old 11th October 2013, 09:48 AM
Default D3 S8 Project Thread
Well, seeing as Oli started one, and it seems like a good idea I thought I'd copy him
To be fair, this S8 is in fairly good condition generally. The underside is remarkably clean, and it does seem overall to be very original.
As ever, theres a few things on every new owners to do list:
1) MOT
2) Fix leaking screenwash
3) Straighten out B&O speaker grills that are mashed in
4) Replace faulty center dash speaker
5) fit AMI
6) Upgrade MMI to later version
7) Fix a an issue with the engine Camshaft positioner
8) Handbrake shows intermittent fault
9) VIM
10) Facelift rear lights (due to peer pressure lol)
11) Gearbox oil change
12) Full service
13) Fit Fridge ?
14) Find a way to grow my own dinosaurs, so I can turn them into petrol to keep this thing fuelled at a sensible cost
1) Done this morning. Few slightly worn suspension advisories, but otherwise all good
2) Thanks to a8parts, a rubber o-ring on the headlight jet was replaced and shes sealed tight now and holding water.
3) Not started yet. Door card off job, but shouldnt be too bad ?
4) Got speaker, hope to do this afternoon
5) Done
6) Done
7) Pending a bit more bravery
8) Pending it becoming a real problem
9) Done
10) On with.
11) Looks tricky due to complex exhaust on S8. But will be done.
12) Will treat it shortly
13) Still miss my fridge so if I can find a cheap one, its in
14) Not sure where to start on this one......
