Old 3rd December 2014, 01:59 PM
Default Headlight washer motor
If the headlight washer motor has gone, would it show up on a VagCom scan?
Old 3rd December 2014, 02:08 PM
I dont think it would, theres no intelligence in it afaik....
Old 3rd December 2014, 04:58 PM
Yeah it's dumb as far as I know. Is it intermittent or completely dead? Mine would work randomly and then not - I thought it was a hose or pressure issue but turned out to be a corroded connector not allowing sufficient current
Old 3rd December 2014, 08:25 PM
Not working at all
Old 3rd December 2014, 09:46 PM
It's 'dumb'.. You need to listen for it when you run it.. usually loud enough to hear when the ignition is on.
Old 3rd December 2014, 10:27 PM
I'm not sure the headlight ones fire every time you use the washers Jim?
Old 4th December 2014, 12:15 AM
I assumed mine weren't working at first, until I discovered one night that when using the washers, they have to be on for several seconds before the ones on the lights would operate, as I tend to give the window short blasts of the washer. Not sure if the lights have to be on as well.
Old 4th December 2014, 04:55 AM
Yes, I've tried holding them on for a while, headlights on and engine running - nothing. But how do you know you can/can't hear it when the windscreen washer motor is running at the same time?
Old 4th December 2014, 06:48 AM
The headlamp one will usually run just afterwards when you let go of the stalk.
Old 4th December 2014, 06:49 AM
I noticed a pool of water on the garage floor this morning, under the front of the car. I'd tried the headlight washers in front of the garage door last night, just before I put the car away - and it wasn't raining.
So maybe just a leak? Fingers crossed - will investigate at the weekend (once I've put the Xmas tree up).
