Old 15th December 2014, 07:24 AM
Oli18's Avatar
Oli18 Oli18 is offline
Default How to change Aux heater glow plug?
Hi,
Does anyone have any instructions on how to change the glow plug on the A's auxiliary heater?
Thanks,
Oliver
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 F
Component: Heizgeraet H07 0110
Revision: 0000000C Serial number: 00000009006406
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 1A31FDBDD5DA2ECE753-804F
2 Faults Found:
01412 - Glow-Plug with Flame Monitoring (Q8)
008 - Implausible Signal
02251 - Heater Unit Locked
000 - -
Audi A8/S8 D2 Flickr Group
Old 15th December 2014, 08:03 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I got a feeling you will need to take the whole unit out to get to the glow plug.
Might as well do this at the same time?
http://www.tyresmoke.net/forum/topic...to-your-a8-d3/
[center]
06 3.0TDI Quattro:
Options:
Old 15th December 2014, 08:13 AM
Glad I took a PDF of that post before the inline images disappeared ...
Old 15th December 2014, 08:28 AM
ScottD3's Avatar
Nice one.
I need to do that retrofit at some point.
[center]
06 3.0TDI Quattro:
Options:
Old 15th December 2014, 12:44 PM
Oli18's Avatar
Thanks guys - really useful!
Don't suppose you have an actual ETKA illustration of the heater and the glow plug location and part number?
Many thanks,
Oliver
* Edit...is this it? and what number would be the glow plug:
Old 15th December 2014, 09:26 PM
Have you tried unblocking it and clearing the codes?
You have to adapt the value of "1" to a value in adaptation channel 7
http://wiki.ross-tech.com/wiki/index.php/02251
It may just be a one-off fluke.
Also what about trying an injector cleaner additive in the fuel?
Good luck, looks a pig of a job really.
Old 21st December 2014, 08:05 PM
Burnzybubbles's Avatar
Just food for thought for you guys but on my e39 I fitted a 12v gsm relay unit in the car and used that to operate the webasto heater, all pin 1 needs is a constant 12v supply to keep it active, the telestart is good as I previously fitted one to the e39 but the gsm unit allows you to turn the heater on from anywhere with phone signal, telestart can only work within a certain range and walls/buildings reduce this range, I used to just txt the car and it'd turn the webasto on
