Old 22nd April 2009, 01:28 PM
harpersimon
Guest
Posts: n/a
yeah send your car over to Blighty, we'll remove just the rear lens.. and send it back. Honest.
Old 23rd February 2010, 12:44 PM
Oli18's Avatar
Oli18 Oli18 is offline
Just got these in the post...i'm so excited i might wet myself! ... they're the proper US ones which i've been after a while. I had a set secured last april but it was lost in transit from Canada I then lost out on an eBay.de auction a while back and it's taken this long to find another set.
Originally Posted by Ian@A8Parts View Post
With the red lens, you need a green light to make an amber light - Thats what our lights in the UK do, they are red to the outside, with a green tint over the bulb so you get orange.... Amazing what you discover when you have a broken one to pull apart
Ian - should it not be a yellow bulb with the red cluster to make an amber light? (see colourwheel here)
Oli
Audi A8/S8 D2 Flickr Group
Old 23rd February 2010, 12:48 PM
Brilliant, been searching myself. If you see any more can you PM and let me know
Old 23rd February 2010, 03:42 PM
A8 3.7 A8 3.7 is offline
I believe the rear lamps are made by Bosch if so their part number will be on the lamp as well as the Audi part number it's a 10 digit number beginning with 0319 which means you should be able to get them from a motor factor that sells Bosch parts and it will be cheaper than Audi. If someone can get me the Bosch part number off the US spec lamps if there is one, I may be able to find out price and availability as I work for a motor factor in South Wales.
Old 23rd February 2010, 04:06 PM
That would be good A8 3.7 but I think that they come with the exact same part number as the UK ones. Can you confirm Oli?
Old 23rd February 2010, 08:29 PM
Oli18's Avatar
Hi,
Just been in the rain trying to change one of the clusters ... it looks good
I only just saw your note on the bosch part number...i'll have a look later and come back to you on that.
Oli
Old 23rd February 2010, 10:25 PM
Mkoneman's Avatar
Mkoneman Mkoneman is offline
looks nice mate, makes all the difference i think
www.facebook.com/obdworks
full genuine ross-tech vcds
full genuine vag- tacho
Old 24th February 2010, 09:40 PM
Oli18's Avatar
Hi A8 3.7 - unfortunately no Bosch numbers on the clusters....just the audi part numbers
4D0 945 095 B
4D0 945 096 B
They are the same numbers as the EU 'pink' parts we get over here though...
I've put the other side on tonight and i haven't changed the bulbs yet....they look brilliant flashing in red...so tempted to keep them. What are the odds i'll get pulled over?!
I'll probably have to change them soon.
Still trying to figure out if i need green or yellow bulbs...though...can anyone confirm? Ian mentioned green but I always thought that green and red turn it into brown and i'm thinking i need a yellow bulb as yellow and red make amber
Thoughts
Old 24th February 2010, 10:21 PM
Mkoneman's Avatar
if you take a standard lens apart there is a green filter inside it
Old 24th February 2010, 10:26 PM
^^^ wot he said - The normal lens has the green bit in, so you just use a normal yellow bulb.
Aside from that, I'm not 100% sure that an indicator has to be orange?
We have loads of Americans nearby due to an army base, and they pottle around in their yank-wagons with UK plates and red blinking lights....
As long as you make it clear you're turning, I'm not convinced it really matters how you do it...
Not sure about hazard warnings though...
