I did this mod today!
![]() The fans are great, although I can't get one of them to stop pointing at the base of the screen. I think that's mainly because I managed to snap one of the mounting clips off it. For anyone else looking to make the swap to the Skoda washers, mine (2008 S8) fit without the spacers. In fact, trying to force it in with a spacer fitted is what caused it to break. I'll pick up another Skoda jet at some point to replace the one I snapped and hopefully it'll line up properly. Thanks guys for all your help! |
Done mine but the part I ordered (5M0955985C) turned up and it doesn't have the plug, just the fluid feed
![]() ![]() It clipped in perfectly, definitely no adapter required (also 2008 S8) Part removed from car: ![]() New part: ![]() Connector which now has nothing to connect to: ![]()
Currently '8-less Previously: - Aqua Blue Pearl D3 S8 - Kamut Beige leather, ACC, B&O, factory RSE, solar sunroof, electric blinds, ski bag, Homelink, comfort headrests. - Aqua Blue D2 S8 - Grey leather/Alcantara - D3 A8 3.0 CVT - D3 3.7 V8 Last edited by Conquistador; 22nd September 2017 at 10:10 AM. |
Yep, wrong part.
The plug is for heating the washer jet. Offhand I don't have the part number. If your car is a 2008 then you mightl not need the spacers. Here are the numbers Adapter part number: 8e0955431 Fan washer part number 5M0955986C Looks like your parts guy has let you down, suggest you return them.
Ray at Wigan Pier 2014 A8L D4 4.0TFSI Gold (Sticker says "Beige") Can't leave you in a black smoke cloud anymore.. In progress, Nothing left to do. Gone 2004 A8 D3 3.0 TDI. Ebony Pearl Black (with little bits of other colours and glitter) Last edited by tc4332; 21st September 2017 at 08:13 PM. |
Yep, my fault and I've reordered the correct part.
![]() I in fact ordered the non-heated version. 5M0955985C is the non-heated version 5M0955986C is the heated version
Currently '8-less Previously: - Aqua Blue Pearl D3 S8 - Kamut Beige leather, ACC, B&O, factory RSE, solar sunroof, electric blinds, ski bag, Homelink, comfort headrests. - Aqua Blue D2 S8 - Grey leather/Alcantara - D3 A8 3.0 CVT - D3 3.7 V8 |
The part number you have stated is correct according to ETKA, Spray nozzle, heated.
Have to say thanks to Snapdragon for originally starting the thread about our windscreen washer jets and for ScottD3 following it up with the fan spray ones available on Skodas.
I have now done my first upgrade on the S8, and they are so much better than the old style. I was quite surprised just how big they were in comparison to the ones on the D2.
Well done Sean.
Nice reminder about a good mod. ![]()
Sean, as you have both a D2 and D3, do you think there's any possibility of a similar upgrade on the D2?
If you look at the first photo I posted with them sitting in my hand, to the left of the water pipe attachment there is a connector. That's the electrical connector, and so allows a faulty one to be replaced. Next to it is a 'blue blob'. If you have a look at the washers on the D2, you will see a similar blob (green I think), which has two wires going into it. That's what leads me to think they are hard wired, and can't be changed as such. I suppose if you really wanted to fit them, you could use the existing wiring from the D2, cutting them off where they enter the green blob. A bit of soldering and the right pins, and you could plug it into the D3 washer. Getting it to sit properly would probably be the hardest part. The D2 ones are attached to a piece of plastic trim at the bottom of the windscreen, the D3 ones are attached to the underside of the bonnet. There is also that significant difference in size, with the D2 being roughly the same size as my thumb.
