Old 30th July 2016, 01:15 PM
mmarksx19 mmarksx19 is offline
Default No sound from drivers door speaker
2007 3.0tdi with std stereo (not bose or b&o). Just one speaker in each front door.
Since I got the car, there has been no sound from the drivers door. Changing the balance and fader across the ranges I can get sound from each extreme except the driver door.
I removed the speaker and plugged it into the passenger door and it worked fine so I know it isn't the speaker itself.
So I think the options are;-
Wiring (nightmare to trace and check I assume)
Amplifier (any tests I can do to check for output on that channel?)
Or component protection (would it stop just one speaker?)
Any suggestions or things I can test?
Michael
2007 A8L 3.0TDi
