Old 11th August 2016, 07:23 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Default Wanted - faulty D2 FL instrument cluster
Anyone got a faulty D2 FL instrument cluster lying about the garage?
Perspex on mine has been cracked since I bought the car and the DIS has 'bled' internally
Going to pull mine apart and sort it all out. (or get it sorted out by a man with right tools in the case of the DIS display!)
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 11th August 2016, 12:16 PM
Have you called our sponsors?
Old 11th August 2016, 02:40 PM
If the sponsors don't have anything suitable, then I have two sitting here, if you want to make an offer. Ironically, both were bought from the forum sponsors.
One is the original one I had replaced. It suffered from 'bleed' in the DIS display and also the odometer. It also suffered from some other electrical issues, so you could use it to experiment on.
The second one works fine. This is the first one I got from the sponsors, but because it had 127k odd miles on it, I didn't want to use it (as you can't change the miles), when mine only had around 60k on it.
Hope to be heading up to Randalstown early next week, so could arrange to drop them off with you.
