The O2 sensors are 5 wire wideband sensors - the colours are: white/pink/yellow/grey/black. I do believe the MPG dropped around the same time as the fans became faulty so I think you may be correct. I've just been unable to find any particular fault which would make the fans run constantly so far. It does have 2 coolant temperature sensors. G62 near the cylinder head (I replaced this one recently) and G83 sensor somewhere near the radiator outlet (although I've never actually been able to find this). My understanding is the G62 is used for fuelling purposes and the G83 is just used for the gauges. If the G83 is also used for fuelling this may be contributing to the fault, though I've not had any fault codes relating to this sensor (assuming it would show up in the engine module). I've watched the data blocks for the G62 temperature sensor and it appears to be working correctly. It climbs up to 90 degrees and stays there, which reflects what the gauge is showing. I've never seen the gauge go above half-way. I've heard that a faulty air-con pressure sensor may also cause one or more fans to run constantly (not sure if this would also cause the main fan to spin). The fans spin constantly whether air-con is turned on or off so I'm not sure if this is the case. I think it does go into closed-loop mode as expected but I will double check. I assume the post-cat O2 sensors are irrelevant in terms of fuelling? I know on most cars they just check catalytic converter efficiency but apparently some also take them into account for fuel correction. I will perform the tests you mentioned in the morning and post an update with my findings. Thanks |
